[OpenLayers-Users] Building a WFS-T-application;
Problem rendering WFS
andreia farrér
andreia.farrer at gmail.com
Mon Aug 16 05:33:26 EDT 2010
Dear List
I am trying to build a WFS-T-application with GeoExt/Openlayers. The
features are stored in a PostGIS-DB and are served by Geoserver.
I managed to retrieve the features (as stated by HttpFox), but somehow they
won't show up in my mappanel. The code is based on the
wfs-states.html-example (http://openlayers.org/dev/examples/wfs-states.html).
I simply can't figure out why the features aren't rendered.
Here's my snippet:
Ext.BLANK_IMAGE_URL = "../ext/resources/images/default/s.gif";
> Ext.onReady(function() {
> OpenLayers.ProxyHost = "../cgi-bin/proxy.cgi?url=";
> var map_options = {maxExtent: new OpenLayers.Bounds(10000, -240000,
> 1380000, 580000),
> numZoomLevels: 12, maxScale: 5000, minScale: 2000000,
> units: 'm', projection: 'EPSG:21781'};
> var map = new OpenLayers.Map(map, map_options,{
> allOverlays: true
> var modifyControl = new
> OpenLayers.Control.ModifyFeature(ogmlines); //ÄNDERN!
> map.addControl(modifyControl);
> modifyControl.activate();
> var saveStrategy = new OpenLayers.Strategy.Save({
> onCommit: function() {
> saveStrategy.ogm_lines.refresh();
> ogmlines = new OpenLayers.Layer.Vector("lines",{
> strategies:[
> new OpenLayers.Strategy.BBOX(),
> saveStrategy
> projection: new OpenLayers.Projection("EPSG:21781"),
> protocol: new OpenLayers.Protocol.WFS({
> version: '1.1.0',
> srsName: 'EPSG:21781',
> url: 'http://localhost:8090/geoserver/wfs',
> //?strict=true
> featureType: 'ogm_lines',
> featurePrefix: 'OpenGeoMap',
> geometryName: 'the_geom',
> extractAttribute: true
> var mapPanel = new GeoExt.MapPanel({
> title: "Map",
> region: "west",
> width: 600,
> map: map,
> layers: [ogmlines],
> //extent: new OpenLayers.Bounds(485000, 63000, 833000,
> 296000),
> bbar: [
> new GeoExt.Action({
> control: new OpenLayers.Control.DrawFeature(
> ogmlines, OpenLayers.Handler.Polygon, {
> //ogmlines!
> handlerOptions: {multi: true}
> text: "Create",
> toggleGroup: "tools",
> map: map
> text: "Delete",
> handler: function() {
> gridPanel.getSelectionModel().each(function(rec) {
> var feature = rec.get("feature");
> modifyControl.unselectFeature(feature);
> gridPanel.store.remove(rec);
> if(feature.state !==
> OpenLayers.State.INSERT) {
> feature.state =
> OpenLayers.State.DELETE;
> ogm_polygons.addFeatures([feature]);
> text: "Save",
> store_polygons.commitChanges();
> saveStrategy.save();
Any help is HIGHLY appreciated.
Kind regards
Andreia
Andreia Farrér, Birmensdorferstr. 260, 8055 Zürich; phone: +41 78 825 44 93
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100816/2ab427f6/attachment.html
