[OpenLayers-Users] External Graphic of features positioning
ilias kanellos
ilias.kanellos at gmail.com
Thu Aug 19 05:02:39 EDT 2010
Dear List,
I am trying to create markers as point features of a vector layer. I do this
by using the following code:
var markerStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default','select']);
markerStyle.graphicWidth = 21;
markerStyle.graphicHeight = 25;
markerStyle.graphicOpacity = 1;
markerStyle.externalGraphic = ""; // I put the
url of the image here
markerStyle.graphicTitle = displayName; //
displayName is a string previously defined
var markerCoordPoint = new
OpenLayers.Geometry.Point(markerCoords.lon,markerCoords.lat); //
markerCoords is a LonLat object
var newMarker = new
OpenLayers.Feature.Vector(markerCoordPoint,null,markerStyle);
When I add the above feature to a vector layer and put in on my map it
displays the image I want in the correct coordinates,
however the center of the image is put to the Lon/Lat coordinates I specify
for the newMarker variable.
What I would like to do is to set a specific point (such as the center of
the bottom, or the bottom left corner) of the image to be put on the
determined coordinates.
I tried to add the following to the markerStyle object:
markerStyle.graphicXOffset =
-(markerStyle.graphicWidth/2);
markerStyle.graphicYOffset =
-markerStyle.graphicHeight;
However if I understood this correctly, the above offset concerns pixels,
and the result is that the marker image gets placed in a completely wrong
position,
especially in low zoom levels. Is there some way to 'anchor' the
externalGraphic the way I want to?
Thank you
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100819/24adb1e8/attachment.html
