[OpenLayers-Users] External Graphic of features positioning
Arnd Wippermann
arnd.wippermann at web.de
Fri Aug 20 08:13:14 EDT 2010
you have to calculate your offset for every zoomlevel. I do it by use of a
styleMap with context. The code below should give you an idea, how to get it
work.
function layerContext()
theXOffset = 10;
theYOffset = 10;
theResolution = map.getResolution();
var context = {
getXO : function(){
return theXOffset * theResolution / map.getResolution();
getYO : function(){
return theYOffset * theResolution / map.getResolution();
var template = {
graphicXOffset : "${getXO}",
graphicYOffset : "${getYO}",
pointRadius : 0
yourLayer.styleMap = new OpenLayers.StyleMap(new
OpenLayers.Style(template, {context:context}) );
I use this approach to display georeferenced images as externalGraphic.
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL27/examples/ExternalGraphicOver
lay/ExternalGraphicOverlay.asp
Arnd
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von ilias kanellos
Gesendet: Donnerstag, 19. August 2010 11:03
An: Users at openlayers.org
Betreff: [OpenLayers-Users] External Graphic of features positioning
Dear List,
I am trying to create markers as point features of a vector layer. I do this
by using the following code:
var markerStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default','select']);
markerStyle.graphicWidth = 21;
markerStyle.graphicHeight = 25;
markerStyle.graphicOpacity = 1;
markerStyle.externalGraphic = ""; // I put the
url of the image here
markerStyle.graphicTitle = displayName; //
displayName is a string previously defined
var markerCoordPoint = new
OpenLayers.Geometry.Point(markerCoords.lon,markerCoords.lat); //
markerCoords is a LonLat object
var newMarker = new
OpenLayers.Feature.Vector(markerCoordPoint,null,markerStyle);
When I add the above feature to a vector layer and put in on my map it
displays the image I want in the correct coordinates,
however the center of the image is put to the Lon/Lat coordinates I specify
for the newMarker variable.
What I would like to do is to set a specific point (such as the center of
the bottom, or the bottom left corner) of the image to be put on the
determined coordinates.
I tried to add the following to the markerStyle object:
markerStyle.graphicXOffset =
-(markerStyle.graphicWidth/2);
markerStyle.graphicYOffset =
-markerStyle.graphicHeight;
However if I understood this correctly, the above offset concerns pixels,
and the result is that the marker image gets placed in a completely wrong
position,
especially in low zoom levels. Is there some way to 'anchor' the
externalGraphic the way I want to?
Thank you
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100820/8f33da48/attachment.html
