[OpenLayers-Users] Map background
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Sun Aug 22 21:14:06 EDT 2010
Changing image format from PNG to JPEG solved the problem.
Unfortunately, my Map service doesn't support GIF so I used JPEG. Anyways,
the problem resolved. So, the trick is not to use PNG in IE6.
Thanks for that Brad.
Cheers,
Kalyan
On Mon, Aug 23, 2010 at 11:02 AM, bradspencer <bradspencer at ozemail.com.au>wrote:
>  Kaylan,
> It could be the image format. I think IE6 has a problem with png images.
> Try gif images on your web map requests and see if that helps.
> Cheers, Brad....
> *From:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *On Behalf Of *Kalyan Kamepalli
> *Sent:* Monday, 23 August 2010 10:59 AM
> *To:* users at openlayers.org
> *Subject:* [OpenLayers-Users] Map background
> Hello everyone,
> Is any one using OpenLayers on IE 6 ? I have a problem here. I initially
> developed a project with OpenLayers on IE8 and everything looks pretty and
> in place ( Like the forms creation, Controls CSS ). I now, have to shift
> this development to IE6 and unfortunately the whole projects seems dim. Most
> of the DOM elements, CSS are not working as they did in IE8. Most of the
> background of Map turned to be a light blue colour in IE6 from white in
> IE8.
> Is there any way to change this back to White in IE6 ? What CSS class
> should I check in to set this ? Are there different classes for different
> browsers ?? Why is it showing two different colours on two versions ?
> Any ideas and experiences with IE6 & OL ??
> Cheers,
> Kalyan
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100823/4a84336e/attachment.html
