[OpenLayers-Users] Map background
Kalyan Kamepalli
kalyan.kamepalli at gmail.com
Sun Aug 22 21:16:22 EDT 2010
I am not using transparent images. But, I think the problem is with the PNG.
I used JPEG and that solved my problem.
Thanks for your information Chris.
Cheers,
On Mon, Aug 23, 2010 at 11:11 AM, <christopher.schmidt at nokia.com> wrote:
> On Aug 22, 2010, at 8:59 PM, ext Kalyan Kamepalli wrote:
> > Hello everyone,
> > Is any one using OpenLayers on IE 6 ? I have a problem here. I initially
> developed a project with OpenLayers on IE8 and everything looks pretty and
> in place ( Like the forms creation, Controls CSS ). I now, have to shift
> this development to IE6 and unfortunately the whole projects seems dim. Most
> of the DOM elements, CSS are not working as they did in IE8. Most of the
> background of Map turned to be a light blue colour in IE6 from white in IE8.
> > Is there any way to change this back to White in IE6 ? What CSS class
> should I check in to set this ? Are there different classes for different
> browsers ?? Why is it showing two different colours on two versions ?
> IE6 does not support alpha-transparent PNGs; you will need to either use
> another image format, or not use transparent images. It is possible,
> if this is on the baselayer of your map, that simply changing our output
> from RGBA to RGB might solve this problem.
> -- Chris
> > Any ideas and experiences with IE6 & OL ??
> > Cheers,
> > Kalyan
> > <ATT00001..txt>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100823/5834e1a2/attachment.html
