[OpenLayers-Users] Busy Status on Map
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Aug 24 08:42:12 EDT 2010
Do you add the control before adding your layers?
Does it work when you zoomin?
What do you see with Firebug?
Bart
> .olControlLoadingPanel {
> background-image: url( ./img/loading.png);
> position: relative;
> width: 195px;
> height: 11px;
> background-position: center;
> background-repeat: no-repeat;
> display: none;
> This is how my CSS looks. I placed my loading.png in img folder. Does it
> make any difference ??
> On Tue, Aug 24, 2010 at 10:33 PM, Bart van den Eijnden (OSGIS) <
> bartvde at osgis.nl> wrote:
>> Did you put the image in your theme dir?
>> Bart
>> > Bart,
>> > I did add the CSS from that wiki page. I just copied it from there and
>> > added
>> > LoaadingPanel control to map. But, I can't get it work.
>> > On Tue, Aug 24, 2010 at 10:26 PM, Bart van den Eijnden (OSGIS) <
>> >> Please read this Wiki page again.
>> >> You need to add css as well, like it says on the page.
>> >> Bart
>> >> > Hi Pavel,
>> >> > I downloaded LoadingPanel.js and added script tag to my html file.
>> >> Added
>> >> > new OpenLayers.Control.LoadingPanel() to my map object. But, I
>> didn't
>> >> see
>> >> > any Image on my map. It just the same as before adding these
>> things.
>> >> Is
>> >> > there something else I may be missing ??
>> >> > Cheers,
>> >> > Kalyan
>> >> > On Tue, Aug 24, 2010 at 9:40 PM, Pavel Iacovlev
>> >> > <iacovlev.pavel at gmail.com>wrote:
>> >> >> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>> >> >> On Tue, Aug 24, 2010 at 2:36 PM, Kalyan Kamepalli <
>> >> >> kalyan.kamepalli at gmail.com> wrote:
>> >> >>> Hello everyone,
>> >> >>> Currently, the OpenLayers is not showing any busy status while
>> >> loading
>> >> >>> map
>> >> >>> data. This is a bit inconvenient for the user. I would like to
>> >> notify
>> >> >>> user
>> >> >>> of the progress.So, Is there a way to add a busy cursor or a
>> >> progress
>> >> >>> bar
>> >> >>> kind of thing on the map div ??
>> >> >>> Thanks,
>> >> >>> Kalyan
>> >> >>> _______________________________________________
>> >> >>> Users mailing list
>> >> >>> Users at openlayers.org
>> >> >>> http://openlayers.org/mailman/listinfo/users
>> >> >> http://iap.md, The future is open
>> >> > Users mailing list
