[OpenLayers-Users] Busy Status on Map
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Tue Aug 24 19:49:20 EDT 2010
Hi Bart,
I added control after adding my layers. Does it make any difference ?? I
have few debugging statements ( alerts ) in initialize , minimizeControl,
maximizeControl functions of LoadingPanel Control and I could see all those
alerts when the map gets loaded. If the alerts are working fine in minimize,
maximize control functions, the image should appear right. But, it is not.
What could be the problem ??
Am I doing something wrong with my image location ?? My loading.gis file is
in /theme/default/img and my main html file is directly under openlayers
directory. My style.css looks this
 .olControlLoadingPanel {
            background-image:url( ./theme/default/img/loading.gif);
            position: relative;
            width: 195px;
            height: 11px;
            background-position:center;
            background-repeat:no-repeat;
            display: none;
As my html file is directly under openLayers , I used single dot ( . )
current directory and then the directory path for url.
Any ideas on why is it still not working ??
On Tue, Aug 24, 2010 at 10:42 PM, Bart van den Eijnden (OSGIS) <
bartvde at osgis.nl> wrote:
> Do you add the control before adding your layers?
> Does it work when you zoomin?
> What do you see with Firebug?
> Bart
> >     background-image: url( ./img/loading.png);
> >     position: relative;
> >     width: 195px;
> >     height: 11px;
> >     background-position: center;
> >     background-repeat: no-repeat;
> >     display: none;
> > This is how my CSS looks. I placed my loading.png in img folder. Does it
> > On Tue, Aug 24, 2010 at 10:33 PM, Bart van den Eijnden (OSGIS) <
> >> Did you put the image in your theme dir?
> >> Bart
> >> > Bart,
> >> > I did add the CSS from that wiki page. I just copied it from there and
> >> > added
> >> > LoaadingPanel control to map. But, I can't get it work.
> >> > On Tue, Aug 24, 2010 at 10:26 PM, Bart van den Eijnden (OSGIS) <
> >> >> Please read this Wiki page again.
> >> >> You need to add css as well, like it says on the page.
> >> >> Bart
> >> >> > Hi Pavel,
> >> >> > I downloaded LoadingPanel.js and added script tag to my html file.
> >> >> Added
> >> >> >  new OpenLayers.Control.LoadingPanel() to my map object. But, I
> >> didn't
> >> >> see
> >> >> > any Image on my map. It just the same as before adding these
> >> things.
> >> >> Is
> >> >> > there something else I may be missing ??
> >> >> > Cheers,
> >> >> > Kalyan
> >> >> > On Tue, Aug 24, 2010 at 9:40 PM, Pavel Iacovlev
> >> >> > <iacovlev.pavel at gmail.com>wrote:
> >> >> >> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> >> >> >> On Tue, Aug 24, 2010 at 2:36 PM, Kalyan Kamepalli <
> >> >> >> kalyan.kamepalli at gmail.com> wrote:
> >> >> >>> Hello everyone,
> >> >> >>> Currently, the OpenLayers is not showing any busy status while
> >> >> loading
> >> >> >>> map
> >> >> >>> data. This is a bit inconvenient for the user. I would like to
> >> >> notify
> >> >> >>> user
> >> >> >>> of the progress.So, Is there a way to add a busy cursor or a
> >> >> progress
> >> >> >>> bar
> >> >> >>> kind of thing on the map div ??
> >> >> >>> Thanks,
> >> >> >>> Kalyan
> >> >> >>> _______________________________________________
> >> >> >>> Users mailing list
> >> >> >>> Users at openlayers.org
> >> >> >>> http://openlayers.org/mailman/listinfo/users
> >> >> >> http://iap.md, The future is open
> >> >> > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100825/ab939079/attachment.html
