[OpenLayers-Users] Permalink doesn't update on
addlayer/removelayer
Slawomir Messner
slawomir.messner at staff.uni-marburg.de
Wed Aug 25 05:21:11 EDT 2010
Ok, now I have realized it completely.
But the third point also matters in the case of "static" maps.
@Andreas: Sry, the first mail should go directly to you.
Regards,
Slawomir
Am 25.08.2010 11:05, schrieb Andreas Hocevar:
> Again, Control.Permalink and Control.ArgParser were designed for maps where users cannot add or remove layers. Once you realize that, you'll see that these controls do their job well.
> For maps where users can add and remove layers, you need your own permalink and argparser implementations.
> Regards,
> Andreas.
> On Aug 25, 2010, at 10:23 , Slawomir Messner wrote:
>> Hi,
>> if I read the code of Permalink and ArgParser right it's a pretty
>> confusing behaviour at all, especially if you have an application with
>> dynamic loading of layers.
>> While I'm working with these controls I noticed some other things:
>> 1. If A sends his link, then changes the visibility of the third layer
>> during his work than A has the same url like B. I think for a normal
>> user pretty confusing to have to different links for one view.
>> 2. If we change Andreas's example a little and B has "&layers=BFT" in
>> the url. At the beginning the views of A and B are equal(if we assume
>> the default config is all layers visible) because ArgParser configures
>> the layer only if there are the same number of layers in url and map:
>> "if (this.layers.length == this.map.layers.length) {"
>> If a user now adds a layer then she/he wonders why his first overlay
>> layer is not visible. This can also happen when he forgets why she/he's
>> on the site because removes the second adds a new one, removes the
>> "second", adds a new one... all is as expected till he adds the third
>> then the second is not visible. This happens because the addlayer
>> listener of ArgParser is unregistered after the line above. That's why
>> standard Permalink and ArgParser combination is only useful to change
>> the initial configuration, this should be mentioned in the documentation.
>> 3. One thing, i would separate visibility and base/overlay-layer. When
>> you have two baselayers in your map ArgParser doesn't parse the "0" for
>> baselayers which are not visible(or not THE baselayer of the map) and
>> the unvisible baselayer becomes an overlay. So something like
>> "&layers=BTBFOTOF" would be better for two baselayers(first the
>> baselayer) and two overlay layer (first visible, second not)... or just
>> make ArgParser parse "0".
>> configureLayers: function() {
>> this.map.events.unregister('addlayer', this, this.configureLayers);
>> for(var i=0, len=this.layers.length; i<len; i++) {
>> var layer = this.map.layers[i];
>> var c = this.layers.charAt(i);
>> if (c == "B") {
>> this.map.setBaseLayer(layer);
>> } else if (c == "0") {
>> layer.isBaseLayer = true; //trigger change-event?
>> } else if ( (c == "T") || (c == "F") ) {
>> layer.setVisibility(c == "T");
>> Regards,
>> Slawomir
>> Am 24.08.2010 15:38, schrieb Andreas Hocevar:
>>> On Aug 24, 2010, at 15:15 , Marc Jansen wrote:
>>>> Hi Andreas,
>>>> first of all, sorry for cross-posting in the past. I thought it was
>>>> useful in this case.
>>>> I'd disagree about the not handling of the layeradd/layerremove event
>>>> for the Permalink-control -- but can easily live without this addition
>>>> to OpenLayers :-)
>>>> Your suggestions of alternative ways of handling application "state" are
>>>> valid and often better suited, yet I think the addition of two
>>>> additional listeners to the control would be very intuitive.
>>> This is where I have to disagree. Let's say you have a map with two pre-configured layers. Now user A, who uses the Permalink control as is, adds a layer, resulting in a permalink with "&layers=BT".
>>> User B has the same map, adds a completely different layer, but uses your add/removelayer aware Permalink control, resulting in a permalink with "&layers=BTT".
>>> Now the interesting part comes when both users send this permalink to someone who opens the permalink. That person will see exactly the same layers with both permalinks - because the map will load only the two pre-configured layers.
>>> This is why I wouldn't consider adding add/removelayer handlers to the Permalink control useful or intuitive at all.
>>> Regards,
>>> Andreas.
>>>> Best regards,
>>>> Marc
>>>> On 24.08.2010 14:49, Andreas Hocevar wrote:
>>>>> Hi,
>>>>> first of all, please don't cross-post dev and users.
>>>>> I am not sure if a permalink as provided by OpenLayers is what you really want for applications where the user can add or remove layers. The permalink only stores the visible/invisible state of the available layers in their order. It does not know anything about what these layers are. So a permalink will look exactly the same for any map with the same extent with let's say 3 layers that are all visible.
>>>>> If you want to store information on what layers are actually configured, you should look into Format.WMC, Format.OWS or solutions like the OpenGeo Suite's GeoExplorer (http://suite.opengeo.org/geoexplorer), which stores layer configurations in a database and provides a permalink with a map id.
>>>>> Regards,
>>>>> Andreas.
>>>>> On Aug 24, 2010, at 14:31 , Marc Jansen wrote:
>>>>>> Hi Slawomir,
>>>>>> I'd consider this a bug with a (on first sight) reasonable easy fix:
>>>>>> In the Permalinks draw-method:
>>>>>> this.map.events.on({
>>>>>> 'moveend': this.updateLink,
>>>>>> 'changelayer': this.updateLink,
>>>>>> 'changebaselayer': this.updateLink,
>>>>>> 'addlayer': this.updateLink,
>>>>>> 'removelayer': this.updateLink,
>>>>>> scope: this
>>>>>> Or one could think of triggering a changelayer event when a layer has
>>>>>> been added/removed in Map.js.
>>>>>> I am unsure which design is better, so I'd suggest opening up a ticket
>>>>>> (I cc'ed the developer list so the core developers notice this discussion).
>>>>>> Regards,
>>>>>> Marc
>>>>>> On 24.08.2010 13:53, Slawomir Messner wrote:
>>>>>>> Hello,
>>>>>>> Does anyone know why Permalink doesn't listen to addlayer/removelayer?
>>>>>>> Every time I add a new layer I have to change a property(i.e.
>>>>>>> visibility) to refresh the link. It's a bug or a feature?
>>>>>>> Regards,
>>>>>>> Slawomir
>>>>>> _______________________________________________
>>>>>> Dev mailing list
>>>>>> Dev at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>> Karten im (Inter|Intra)net?
>>>> OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
>>>> von M. Jansen und T. Adams, OpenSourcePress, München.
>>>> ISBN: 978-3-937514-92-5
>>>> URL: http://openlayers-buch.de
>>>> Dipl.-Geogr. Marc Jansen
>>>> - Anwendungsentwickler -
>>>> terrestris GmbH& Co. KG
>>>> Irmintrudisstraße 17
>>>> 53111 Bonn
>>>> Tel: ++49 (0)228 / 96 28 99 -53
>>>> Fax: ++49 (0)228 / 96 28 99 -57
>>>> Email: jansen at terrestris.de
>>>> Web: http://www.terrestris.de
>>>> Amtsgericht Bonn, HRA 6835
>>>> Komplementärin: terrestris Verwaltungsgesellschaft mbH
>>>> vertreten durch: Hinrich Paulsen, Till Adams
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> Slawomir Messner
>> Forschungszentrum "Deutscher Sprachatlas"
>> Users mailing list
Slawomir Messner
06421-28-24981
