[OpenLayers-Users] Permalink doesn't update on
addlayer/removelayer
Slawomir Messner
slawomir.messner at staff.uni-marburg.de
Wed Aug 25 05:22:38 EDT 2010
should go = shouldn't go
Sry, again...
Am 25.08.2010 11:21, schrieb Slawomir Messner:
> Ok, now I have realized it completely.
> But the third point also matters in the case of "static" maps.
> @Andreas: Sry, the first mail should go directly to you.
> Regards,
> Slawomir
> Am 25.08.2010 11:05, schrieb Andreas Hocevar:
>> Again, Control.Permalink and Control.ArgParser were designed for maps
>> where users cannot add or remove layers. Once you realize that,
>> you'll see that these controls do their job well.
>> For maps where users can add and remove layers, you need your own
>> permalink and argparser implementations.
>> Regards,
>> Andreas.
>> On Aug 25, 2010, at 10:23 , Slawomir Messner wrote:
>>> Hi,
>>> if I read the code of Permalink and ArgParser right it's a pretty
>>> confusing behaviour at all, especially if you have an application with
>>> dynamic loading of layers.
>>> While I'm working with these controls I noticed some other things:
>>> 1. If A sends his link, then changes the visibility of the third layer
>>> during his work than A has the same url like B. I think for a normal
>>> user pretty confusing to have to different links for one view.
>>> 2. If we change Andreas's example a little and B has "&layers=BFT" in
>>> the url. At the beginning the views of A and B are equal(if we assume
>>> the default config is all layers visible) because ArgParser configures
>>> the layer only if there are the same number of layers in url and map:
>>> "if (this.layers.length == this.map.layers.length) {"
>>> If a user now adds a layer then she/he wonders why his first overlay
>>> layer is not visible. This can also happen when he forgets why she/he's
>>> on the site because removes the second adds a new one, removes the
>>> "second", adds a new one... all is as expected till he adds the third
>>> then the second is not visible. This happens because the addlayer
>>> listener of ArgParser is unregistered after the line above. That's why
>>> standard Permalink and ArgParser combination is only useful to change
>>> the initial configuration, this should be mentioned in the
>>> documentation.
>>> 3. One thing, i would separate visibility and base/overlay-layer. When
>>> you have two baselayers in your map ArgParser doesn't parse the "0" for
>>> baselayers which are not visible(or not THE baselayer of the map) and
>>> the unvisible baselayer becomes an overlay. So something like
>>> "&layers=BTBFOTOF" would be better for two baselayers(first the
>>> baselayer) and two overlay layer (first visible, second not)... or just
>>> make ArgParser parse "0".
>>> configureLayers: function() {
>>> this.map.events.unregister('addlayer', this,
>>> this.configureLayers);
>>> for(var i=0, len=this.layers.length; i<len; i++) {
>>> var layer = this.map.layers[i];
>>> var c = this.layers.charAt(i);
>>> if (c == "B") {
>>> this.map.setBaseLayer(layer);
>>> } else if (c == "0") {
>>> layer.isBaseLayer = true; //trigger change-event?
>>> } else if ( (c == "T") || (c == "F") ) {
>>> layer.setVisibility(c == "T");
>>> Regards,
>>> Slawomir
>>> Am 24.08.2010 15:38, schrieb Andreas Hocevar:
>>>> On Aug 24, 2010, at 15:15 , Marc Jansen wrote:
>>>>> Hi Andreas,
>>>>> first of all, sorry for cross-posting in the past. I thought it was
>>>>> useful in this case.
>>>>> I'd disagree about the not handling of the layeradd/layerremove event
>>>>> for the Permalink-control -- but can easily live without this
>>>>> addition
>>>>> to OpenLayers :-)
>>>>> Your suggestions of alternative ways of handling application
>>>>> "state" are
>>>>> valid and often better suited, yet I think the addition of two
>>>>> additional listeners to the control would be very intuitive.
>>>> This is where I have to disagree. Let's say you have a map with two
>>>> pre-configured layers. Now user A, who uses the Permalink control
>>>> as is, adds a layer, resulting in a permalink with "&layers=BT".
>>>> User B has the same map, adds a completely different layer, but
>>>> uses your add/removelayer aware Permalink control, resulting in a
>>>> permalink with "&layers=BTT".
>>>> Now the interesting part comes when both users send this permalink
>>>> to someone who opens the permalink. That person will see exactly
>>>> the same layers with both permalinks - because the map will load
>>>> only the two pre-configured layers.
>>>> This is why I wouldn't consider adding add/removelayer handlers to
>>>> the Permalink control useful or intuitive at all.
>>>> Regards,
>>>> Andreas.
>>>>> Best regards,
>>>>> Marc
>>>>> On 24.08.2010 14:49, Andreas Hocevar wrote:
>>>>>> Hi,
>>>>>> first of all, please don't cross-post dev and users.
>>>>>> I am not sure if a permalink as provided by OpenLayers is what
>>>>>> you really want for applications where the user can add or remove
>>>>>> layers. The permalink only stores the visible/invisible state of
>>>>>> the available layers in their order. It does not know anything
>>>>>> about what these layers are. So a permalink will look exactly the
>>>>>> same for any map with the same extent with let's say 3 layers
>>>>>> that are all visible.
>>>>>> If you want to store information on what layers are actually
>>>>>> configured, you should look into Format.WMC, Format.OWS or
>>>>>> solutions like the OpenGeo Suite's GeoExplorer
>>>>>> (http://suite.opengeo.org/geoexplorer), which stores layer
>>>>>> configurations in a database and provides a permalink with a map id.
>>>>>> Regards,
>>>>>> Andreas.
>>>>>> On Aug 24, 2010, at 14:31 , Marc Jansen wrote:
>>>>>>> Hi Slawomir,
>>>>>>> I'd consider this a bug with a (on first sight) reasonable easy
>>>>>>> fix:
>>>>>>> In the Permalinks draw-method:
>>>>>>> this.map.events.on({
>>>>>>> 'moveend': this.updateLink,
>>>>>>> 'changelayer': this.updateLink,
>>>>>>> 'changebaselayer': this.updateLink,
>>>>>>> 'addlayer': this.updateLink,
>>>>>>> 'removelayer': this.updateLink,
>>>>>>> scope: this
>>>>>>> Or one could think of triggering a changelayer event when a
>>>>>>> layer has
>>>>>>> been added/removed in Map.js.
>>>>>>> I am unsure which design is better, so I'd suggest opening up a
>>>>>>> ticket
>>>>>>> (I cc'ed the developer list so the core developers notice this
>>>>>>> discussion).
>>>>>>> Regards,
>>>>>>> Marc
>>>>>>> On 24.08.2010 13:53, Slawomir Messner wrote:
>>>>>>>> Hello,
>>>>>>>> Does anyone know why Permalink doesn't listen to
>>>>>>>> addlayer/removelayer?
>>>>>>>> Every time I add a new layer I have to change a property(i.e.
>>>>>>>> visibility) to refresh the link. It's a bug or a feature?
>>>>>>>> Regards,
>>>>>>>> Slawomir
>>>>>>> _______________________________________________
>>>>>>> Dev mailing list
>>>>>>> Dev at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>> Karten im (Inter|Intra)net?
>>>>> OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
>>>>> von M. Jansen und T. Adams, OpenSourcePress, München.
>>>>> ISBN: 978-3-937514-92-5
>>>>> URL: http://openlayers-buch.de
>>>>> Dipl.-Geogr. Marc Jansen
>>>>> - Anwendungsentwickler -
>>>>> terrestris GmbH& Co. KG
>>>>> Irmintrudisstraße 17
>>>>> 53111 Bonn
>>>>> Tel: ++49 (0)228 / 96 28 99 -53
>>>>> Fax: ++49 (0)228 / 96 28 99 -57
>>>>> Email: jansen at terrestris.de
>>>>> Web: http://www.terrestris.de
>>>>> Amtsgericht Bonn, HRA 6835
>>>>> Komplementärin: terrestris Verwaltungsgesellschaft mbH
>>>>> vertreten durch: Hinrich Paulsen, Till Adams
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>> Slawomir Messner
>>> Forschungszentrum "Deutscher Sprachatlas"
>>> Users mailing list
Slawomir Messner
06421-28-24981
