[OpenLayers-Users] WMS getFeatureInfo Popup
Kiks enrico.oemi at gmail.com
Fri Aug 27 04:12:42 EDT 2010
After replacing special characters, passing the url to the browser, it
happens that the url is not valid due to the absence of the map parameter
requested from mapserver.
I tried to add the map parameter and also to pass it directly in the url
parameter as you can see below:
info = new OpenLayers.Control.WMSGetFeatureInfo({
				url: 'http://localhost/mapserverms4w/mapserv.exe',
                                // Second case // url:
'http://cadastralgis.selfip.com/mapserverms4w/mapserv.exe?map=CGGoogleNoTransform.map',
				map: 'CGGoogleNoTransform.map',
				title: 'Identify features by clicking',
				queryVisible: true,
				eventListeners: {
					getfeatureinfo: function(event) {
						map.addPopup(new OpenLayers.Popup.AnchoredBubble(
							map.getLonLatFromPixel(event.xy),
							null,
							event.text,
							null,
							true
, but in the first case the parameter map is ignored, and in the second
case, the popup is not showed, nothing happens and the IIS log is this:
127.0.0.1, -, 27/08/2010, 10.05.58, W3SVC1, FSC421214090108, 127.0.0.1,
4125, 861, 24387, 200, 0, GET, /mapserverms4w/mapserv.exe,
MAP=CGGoogleNoTransForm.map&LAYERS=CG_GEO_PARTICELLE%2CCG_GEO_STRADE%2CCG_GEO_ACQUE%2CCG_GEO_FABBRICATI%2CCG_GEO_TESTI%2CCG_GEO_PARTICELLE_LABEL&FORMAT=aggpng24&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=1075949.4509402,5550294.3377254,1076560.9471664,5550905.8339516&WIDTH=256&HEIGHT=256,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-getFeatureInfo-Popup-tp5355333p5468577.html
