[OpenLayers-Users] WMS getFeatureInfo Popup
David Fawcett
david.fawcett at gmail.com
Fri Aug 27 10:17:47 EDT 2010
When you include your map parameter in the base URL, do you get a
valid WMS URL?
On Fri, Aug 27, 2010 at 3:12 AM, Kiks <enrico.oemi at gmail.com> wrote:
> After replacing special characters, passing the url to the browser, it
> happens that the url is not valid due to the absence of the map parameter
> requested from mapserver.
> I tried to add the map parameter and also to pass it directly in the url
> parameter as you can see below:
> info = new OpenLayers.Control.WMSGetFeatureInfo({
> url: 'http://localhost/mapserverms4w/mapserv.exe',
> // Second case // url:
> 'http://cadastralgis.selfip.com/mapserverms4w/mapserv.exe?map=CGGoogleNoTransform.map',
> map: 'CGGoogleNoTransform.map',
> title: 'Identify features by clicking',
> queryVisible: true,
> eventListeners: {
> getfeatureinfo: function(event) {
> map.addPopup(new OpenLayers.Popup.AnchoredBubble(
> map.getLonLatFromPixel(event.xy),
> null,
> event.text,
> null,
> true
> , but in the first case the parameter map is ignored, and in the second
> case, the popup is not showed, nothing happens and the IIS log is this:
> 127.0.0.1, -, 27/08/2010, 10.05.58, W3SVC1, FSC421214090108, 127.0.0.1,
> 4125, 861, 24387, 200, 0, GET, /mapserverms4w/mapserv.exe,
> MAP=CGGoogleNoTransForm.map&LAYERS=CG_GEO_PARTICELLE%2CCG_GEO_STRADE%2CCG_GEO_ACQUE%2CCG_GEO_FABBRICATI%2CCG_GEO_TESTI%2CCG_GEO_PARTICELLE_LABEL&FORMAT=aggpng24&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=1075949.4509402,5550294.3377254,1076560.9471664,5550905.8339516&WIDTH=256&HEIGHT=256,
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-getFeatureInfo-Popup-tp5355333p5468577.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
