[OpenLayers-Users] proxy.cgi fails
Marc Jansen
jansen at terrestris.de
Fri Aug 27 04:22:46 EDT 2010
Hi Sven,
Just some thoughts/questions:
* What is the exact server message?
* Is your test.cgi a python cgi?
* Can proxy.cgi find the pythoin executable?
* On a terminal on that machine issue
which python
This should give you the path to the python executable
(/path/to/python). Replace the first line in the proxy.cgi script
#!/usr/bin/env python
to the output of 'which'
#!/path/to/python
* Is the script executable (check it with ls -la, maybe add it with
chmod +x proxy.cgi)
Regards,
Marc
On 27.08.2010 09:36, Sven Burbeck wrote:
> Hello,
> sorry for asking stupid newbie questions but I fail to get the
> proxi.cgi working.
> I followed the FAQ description:
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
> I've installed Apache 2.2.13 on SUSE11.2 via rpm.
> Apparently the default cgi-bin is under /srv/www/cgi-bin
> I put a test.cgi there and it works when calling it:
> http://localhost/cgi-bin/test.cgi
> However, trying the same with proxy.cgi fails.
> Is there anything else I have to consider?
> cheers,
> Sven
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100827/df97aae7/attachment.html
