[OpenLayers-Users] proxy.cgi fails
Marc Jansen
jansen at terrestris.de
Fri Aug 27 07:03:54 EDT 2010
Hi Sven,
are you using another proxy to access URLs in your network? I found this
Mailinglist discussion
http://mail.python.org/pipermail/python-list/2008-December/569855.html
If that is still not doing the trick, I',m afraid I am running out of
ideas soon.
Regards,
Marc
On 27.08.2010 12:40, Sven Burbeck wrote:
> Hi,
> the firewall is off.
> Entering http://example.com/cgi-bin/proxy.cgi
> manually in the browser brings up the following message:
> Not Found
> The requested URL /cgi-bin/proxy.cgi was not found on this server.
> Apache/2.2.3 (CentOS) Server at example.com Port 80
> entering http://localhost/cgi-bin/proxy.cgi
> brings up:
> waiting for localhost...
> <urlopen error [Errno 110] Connection timed out>
> cheers,
> Sven
> Quoting "Marc Jansen"<jansen at terrestris.de>:
>> Hi Sven,
>> Is there some firewall active on the server?
>> What do you see if you enter http://example.com/cgi-bin/proxy.cgi in
>> your browser manually? When called without parameters, it'll try to
>> access www.openlayers.org.
>> You should see the OpenLayers Homepage served by your proxy (You'll need
>> to allow the host www.openlayers.org though)
>> Regards,
>> Marc
>> On 27.08.2010 11:04, Sven Burbeck wrote:
>>> Hi Marc,
>>> 1.) Browser indicates: "waiting for localhost" and finally:
>>> "<urlopen error [Errno 110] Connection timed out>"
>>> 2.) mytest.cgi indeed wasn't Python but Perl. However, I changed it
>>> to Python
>>> Content:
>>> #!/usr/bin/python
>>> print "Content-type: text/html\r\n\r\n";
>>> print "Python CGI works";
>>> and it works!
>>> 3.) changed first line in proxy.cgi to #!/usr/bin/python
>>> but to no avail. The problem remains.
>>> Any idea?
>>> Sven
>>>> Hi Sven,
>>>> Just some thoughts/questions:
>>>> * What is the exact server message?
>>>> * Is your test.cgi a python cgi?
>>>> * Can proxy.cgi find the pythoin executable?
>>>> * On a terminal on that machine issue
>>>> which python
>>>> This should give you the path to the python executable
>>>> (/path/to/python). Replace the first line in the proxy.cgi script
>>>> #!/usr/bin/env python
>>>> to the output of 'which'
>>>> #!/path/to/python
>>>> * Is the script executable (check it with ls -la, maybe add it with
>>>> chmod +x proxy.cgi)
>>>> Regards,
>>>> Marc
>>>> On 27.08.2010 09:36, Sven Burbeck wrote:
>>>>> Hello,
>>>>> sorry for asking stupid newbie questions but I fail to get the
>>>>> proxi.cgi working.
>>>>> I followed the FAQ description:
>>>>> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
>>>>> I've installed Apache 2.2.13 on SUSE11.2 via rpm.
>>>>> Apparently the default cgi-bin is under /srv/www/cgi-bin
>>>>> I put a test.cgi there and it works when calling it:
>>>>> http://localhost/cgi-bin/test.cgi
>>>>> However, trying the same with proxy.cgi fails.
>>>>> Is there anything else I have to consider?
>>>>> cheers,
>>>>> Sven
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> Users mailing list
> Users mailing list
Karten im (Inter|Intra)net?
OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
von M. Jansen und T. Adams, OpenSourcePress, München.
ISBN: 978-3-937514-92-5
URL: http://openlayers-buch.de
Dipl.-Geogr. Marc Jansen
- Anwendungsentwickler -
terrestris GmbH& Co. KG
Irmintrudisstraße 17
53111 Bonn
Tel: ++49 (0)228 / 96 28 99 -53
Fax: ++49 (0)228 / 96 28 99 -57
Email: jansen at terrestris.de
Web: http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Hinrich Paulsen, Till Adams
