[OpenLayers-Users] proxy.cgi fails
Sven Burbeck
sburbeck at bfs.de
Fri Aug 27 06:40:25 EDT 2010
the firewall is off.
Entering http://example.com/cgi-bin/proxy.cgi
manually in the browser brings up the following message:
Not Found
The requested URL /cgi-bin/proxy.cgi was not found on this server.
Apache/2.2.3 (CentOS) Server at example.com Port 80
entering http://localhost/cgi-bin/proxy.cgi
brings up:
waiting for localhost...
<urlopen error [Errno 110] Connection timed out>
cheers,
Sven
Quoting "Marc Jansen" <jansen at terrestris.de>:
> Hi Sven,
> Is there some firewall active on the server?
> What do you see if you enter http://example.com/cgi-bin/proxy.cgi in
> your browser manually? When called without parameters, it'll try to
> access www.openlayers.org.
> You should see the OpenLayers Homepage served by your proxy (You'll need
> to allow the host www.openlayers.org though)
> Regards,
> Marc
> On 27.08.2010 11:04, Sven Burbeck wrote:
>> Hi Marc,
>> 1.) Browser indicates: "waiting for localhost" and finally:
>> "<urlopen error [Errno 110] Connection timed out>"
>> 2.) mytest.cgi indeed wasn't Python but Perl. However, I changed it
>> to Python
>> Content:
>> #!/usr/bin/python
>> print "Content-type: text/html\r\n\r\n";
>> print "Python CGI works";
>> and it works!
>> 3.) changed first line in proxy.cgi to #!/usr/bin/python
>> but to no avail. The problem remains.
>> Any idea?
>> Sven
>> Quoting "Marc Jansen"<jansen at terrestris.de>:
>>> Hi Sven,
>>> Just some thoughts/questions:
>>> * What is the exact server message?
>>> * Is your test.cgi a python cgi?
>>> * Can proxy.cgi find the pythoin executable?
>>> * On a terminal on that machine issue
>>> which python
>>> This should give you the path to the python executable
>>> (/path/to/python). Replace the first line in the proxy.cgi script
>>> #!/usr/bin/env python
>>> to the output of 'which'
>>> #!/path/to/python
>>> * Is the script executable (check it with ls -la, maybe add it with
>>> chmod +x proxy.cgi)
>>> Regards,
>>> Marc
>>> On 27.08.2010 09:36, Sven Burbeck wrote:
>>>> Hello,
>>>> sorry for asking stupid newbie questions but I fail to get the
>>>> proxi.cgi working.
>>>> I followed the FAQ description:
>>>> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
>>>> I've installed Apache 2.2.13 on SUSE11.2 via rpm.
>>>> Apparently the default cgi-bin is under /srv/www/cgi-bin
>>>> I put a test.cgi there and it works when calling it:
>>>> http://localhost/cgi-bin/test.cgi
>>>> However, trying the same with proxy.cgi fails.
>>>> Is there anything else I have to consider?
>>>> cheers,
>>>> Sven
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> Users mailing list
