[OpenLayers-Users] Pointlist of Polygon
Max Weidemann max.weidemann at freenet.de
Fri Feb 5 07:14:47 EST 2010
Hi frotho,
You have too look at the Vector layer.
In your case
---> var
lastGeometry=vectors.features[(vectors.features.length-1)].geometry;
will give you the last geometry from the layer.
To get the points from an Polygon you have look at the components array.
---> var points=lastGeometry.components
I hope this will help you.
cheers
Max
View this message in context: http://n2.nabble.com/Pointlist-of-Polygon-tp4519183p4519574.html
