[OpenLayers-Users] Optimizing OpenLayers - missing images
Christopher Schmidt crschmidt at metacarta.com
Wed Feb 10 16:58:52 EST 2010
On Wed, Feb 10, 2010 at 01:44:16PM -0800, Dash wrote:
> Hey folks,
> I am trying to optimize OpenLayers and everything is working great except
> I'm missing some images for my controls.  First, I downloaded OpenLayers2.8.
> Then I ran build.py and created the library.cfg file.  I moved this file and
> the other recommended directories to our web server (build/OpenLayers.js and
> theme/ and img/ directories).  I set the path of OpenLayers.js to reflect
> the new configuration and successfully tested my site.  This is when I
> noticed the missing images.
http://docs.openlayers.org/library/deploying.html#deploying-files
-- Chris
> Issues:
> 1) Missing close box image for popups.  It used to be there when I was
> accessing OpenLayers.js from http://openlayers.org/dev/lib/OpenLayers.js.
> Now it's not.
> 2) I've also noticed the layer-switcher-minimize.png is not showing up.
> 3) Also, the mouse position control has shifted from the bottom left to the
> upper right of the map.
> Has anyone experienced these anomlyes?  If so, how did you rectify them?
> Any help would be greatly appreciated.
> Thanks...
> View this message in context: http://n2.nabble.com/Optimizing-OpenLayers-missing-images-tp4551053p4551053.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
