[OpenLayers-Users] Overview map with ArcIMS breaks
Vadim Bokin vbokin at gmail.com
Thu Feb 18 19:03:07 EST 2010
Created a new ticket on Trac but didn't get a response there, so I'm
wondering if this is a user error API error
(http://trac.openlayers.org/ticket/2490).
When an ArcIMS layer is a base layer, the overview map doesn't load and
errors are throw in
Grid.js.addTileMonitoringHooks(tile)
the "tile" that is passed is undefined. I was able to trace it back to
Grid.js.initGriddedTiles(..)
    => line 408
     if (!tile) {
                        tile = this.addTile(tileBounds, px);
                        this.addTileMonitoringHooks(tile);
                        row.push(tile);
                    } else {
                        tile.moveTo(tileBounds, px, false);
The call to
returns undefined. So it seems that the actual error is in
ArcIMS.js.addTile(...)
To replicate:
1) Take the basic ArcIMS example
    http://www.openlayers.org/dev/examples/arcims.html
2) Add 1 line at the end of the init() routine to add the overview map
    map.addControl (new OpenLayers.Control.OverviewMap( ) );
3) Load sample HTML file -> map loads, but the overview control throws
errors
Are there any parameters I can pass in to OverviewMap to make it work?
I've tried it WMS and ArcGIS (both Tile based layers) and they both worked.
Thanks,
-Vadim
View this message in context: http://n2.nabble.com/Overview-map-with-ArcIMS-breaks-tp4595244p4595244.html
