[OpenLayers-Users] Changing the srs of a map
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Feb 19 03:54:20 EST 2010
On Friday, February 19, 2010, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Thu, Feb 18, 2010 at 11:25:39PM +0100, Andreas Hocevar wrote:
>> Phil Scadden wrote:
>> > I am wanting to change the SRS of map "on the fly", (largely dependent
>> > on what imagery is selected am using as a backdrop). Can you just change
>> > it for an existing map or do you have to destroy the map and recreate
>> > with a the new srs?
>> If your backdrop is a base layer, and configured with the right srs, the
>> map will automatically switch to the srs that is configured for the base
>> layer.
> Sort of. Vectors loaded statically won't reproject.
+ I think one needs to reconfigure the overlays, i.e. set the
projection, recalculate min/maxResolution, etc.
We, at Camptocamp, have been working on a SelectZone control. This
control allows switching to a new geographic zone, with a new
projection, max extent etc. Switching zone can be done manually using
control.select(newzone) or automatically on zoom in/out.
See the example
<http://trac.openlayers.org/browser/sandbox/elemoine/reproject/examples/reproject-map.html>.
The example includes the code of the Control.
This control relies on three OpenLayers patches, see #2360, #2427, and
#2359. I think these patches could be useful for other "reproject map"
implementations than our SelectZone control.
Also, note that the control doesn't currently support reprojecting
vectors, but adding that shoudn't be a problem.
And FYI we've been thinking about making the SelectZone an OpenLayers
addin, but we haven't gotten to that at this point.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
