[OpenLayers-Users] GWt + Openlayers - problem:GOOGLE layer
appears in left corner
And.
asufsc at gmail.com
Tue Feb 23 12:43:39 EST 2010
If you show your code will be easier to help.
Btw,
1) check if you are setting all params to the object map;
2) check if you are setting all params to the gmaps layers;
3) call the method updateSize() (Map.java);
4) then set the center (don't forget to transform the coordinates to
EPSG900913);
It should work.
Regards,
And.
View this message in context: http://n2.nabble.com/GWt-Openlayers-problem-GOOGLE-layer-appears-in-left-corner-tp4619582p4620546.html
