[OpenLayers-Users] question about select feature
    Karina Guardado
    kguardado at gmail.com
    Tue Feb 23 12:55:38 EST 2010
Hello everybody,
I have 2 layers that are point type and I want users to be able to click on
one point (of any layer) and get the information(attributes) related to that
point. Here is my code
 var estaciones = new OpenLayers.Layer.WMS("estaciones",
"http://myurl/cgi-bin/mapserv?MAP=/var/www/amss_wms2.map",
                {layers:'estaciones', transparent:
"true",format:"image/gif"});
    var puntos = new OpenLayers.Layer.WMS("puntos",
                "http://myurl/cgi-bin/mapserv?MAP=/var/www/amss_wms2.mapl",
                {layers:'puntos', transparent: "true",format:"image/gif"});
so far what I was using was a text layer to generate a marker and then get
the information  as follows:
var  infpuntos = new OpenLayers.Layer.Text( "infpuntos", {location:
"textpunto.php"},
http://myurl/cgi-bin/mapserv?MAP=/var/www/amss_wms2.map");
var  infestaciones = new OpenLayers.Layer.Text( "infestaciones", {location:
"textpunto.php"},    "
but I would like that users could be able to click on one point and get the
information without using this text markers. I found information about
vector and gml layers with text format but I would like to know how to use
them to work with more than one layer  or if there are other solutions that
someone could recomend.
thanks in advance.
Karina Guardado
El Salvador
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100223/4269dac3/attachment.html
