[OpenLayers-Users] Layer.WMS.Post and loadstart-loadend event
Bart van den Eijnden
bartvde at osgis.nl
Tue Feb 23 12:19:12 EST 2010
Hi Steve,
FYI, this has just been fixed in OpenLayers trunk, see ticket 2406 for the details.
Best regards,
Bart
On Jan 8, 2010, at 4:36 PM, Steve.Toutant at inspq.qc.ca wrote:
> Thanks Bart,
> I created a ticket (#2405...and 2406).
> http://trac.openlayers.org/ticket/2405
> I tried it twice because I got an error message saying that my attached file was too big. It is only 284ko...
> It is my first ticket, I might missed something. If the file is not attached, tell me how to send it please.
> I used the loadingPanel example. Using the layer switcher, the problen also occurs in IE.
> Steve
> Bart van den Eijnden <bartvde at osgis.nl>
> 07/01/2010 04:14 PM
> A
> cc
> users at openlayers.org
> Objet
> Re: [OpenLayers-Users] Layer.WMS.Post and loadstart-loadend event
> Hi Steve,
> this sounds like an OpenLayers issue.
> Can you please open up a Trac ticket in the OpenLayers Trac with a reproducable testcase?
> The iframe code (which is used by the POST WMS layer) in OL does have some logic for the loadend event, but maybe something is going wrong somehwere, we will be able to debug once you submit a reproducable testcase. TIA.
> Best regards,
> Bart
> On Jan 7, 2010, at 9:04 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> I'm using Layer.WMS.Post for one of my layers since the geometry comes from a complex query and GET method often doesn't work in IE.
> For this layer when I check this layer in mapfish layertree widget (Ext.treepanel) I got a progress bar that starts but never stops.
> If I create this layer with Layer.WMS with a simple query the progress bar disapear.
> Is it because Layer.WMS.Post doesn't have a loadend event? I don't know how to verify this.
> I'm using OpenLayers.Control.LoadingPanel example
> Please tell me if this is a mapfish issue.
> Thanks
> Steve
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144
> steve.toutant at inspq.qc.ca
> http://www.inspq.qc.ca
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100223/0f959bdf/attachment.html
