[OpenLayers-Users] Problems with overview map and Chrome
David Alda Fernandez de Lezea dalda at ikt.es
Tue Feb 23 11:33:39 EST 2010
I'm having some troubles with overviewMap control and chrome, when I click (+) to expand the control, it appears on the left top corner of the control, on the right bottom corner of the map, and I can´t see what's in it. I've read something about this problem related with chrome and using layer.clone() but the example of the openlayers webpage works perfect with chrome, and also the layer I'm using with the overview map is a totally different layer. In fact it's not added to the map. My code:
var wms = new OpenLayers.Layer.WMS("mapOverView","http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wms.map", {layers: 'mapOverView',format: 'image/png; mode=24bit',alpha : 'true',transparent: 'true'},{isBaseLayer: true,projection: 'EPSG:23030',units: 'm'});
var opt = {mapOptions: {projection: new OpenLayers.Projection("EPSG:23030"),units: 'm',numZoomLevels: [1],maxExtent: new OpenLayers.Bounds(460000, 4710000, 610000, 4820000), maxResolution: 'auto'}, layers: [wms]};
var ovmCtrl = new OpenLayers.Control.OverviewMap(opt);
What could be happening??
TIA.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
email: dalda at ikt.es                                web: www.ikt.es
