[OpenLayers-Users] GWt + Openlayers - problem:GOOGLE layer
appears in left corner
And.
asufsc at gmail.com
Fri Feb 26 13:37:58 EST 2010
paweluz wrote:
> Hi And!
> Thanks for your help. I do not have any method updateSize() on my map...
> Below is my code...I hope you could help me... I removed the WMS layer
> from the code, because with or without it I still got the same problem...
> private void initializeGooglLayer(){
> GoogleOptions googleLayeroptions= new GoogleOptions();
> googleLayeroptions.setIsBaseLayer(true);
> googleLayeroptions.setSphericalMercator(true);
> googleLayeroptions.setDisplayInLayerSwitcher(true);
> googleLayeroptions.setDisplayOutsideMaxExtent(true);
> GMapType gmapType = GMapType.G_NORMAL_MAP;
> googleLayeroptions.setType(gmapType);
> googleLayer = new Google("Goole Layer",googleLayeroptions);
> private void initializeMap(){
> MapOptions mapOptions = new MapOptions();
> mapOptions.setControls(new JObjectArray(new JSObject[] {}));
> mapOptions.setNumZoomLevels(17);
> mapOptions.setMaxResolution((float) 156543.0339);
> Bounds myBounds = new Bounds(-20037508, -20037508,20037508,
> 20037508);
> mapOptions.setMaxExtent(myBounds);
> Projection myProjection = new Projection("EPSG:900913");
> mapOptions.setProjection("EPSG:900913");
> mapOptions.setDisplayProjection(myProjection);
> mapWidget = new MapWidget("750px", "600px", mapOptions);
> myMap = mapWidget.getMap();
> this.initializeGooglLayer(); // initialize Google layer
> myMap.addLayers(new Layer[] {googleLayer});
> myMap.addControl(new PanZoomBar());
> myMap.addControl(new MousePosition());
> myMap.addControl(new LayerSwitcher());
> myMap.addControl(new Navigation());
> LonLat center = new LonLat(1722814.18028, 6792060.56768);
> myMap.setCenter(center, 14);
> public void onModuleLoad() {
> this.initializeMap();
> openlayersPanel.add(mapWidget,DockPanel.CENTER);
> addPanel.add(openlayersPanel);
> mainPanel.add(addPanel);
> RootPanel.get("mainDiv").add(mainPanel);
> Regards,
> Poul
Then create it.
public static native void updateSize(JSObject map)/*-{
map.updateSize();
You just need pass as parameter to this method the object map.getJSObject();
View this message in context: http://n2.nabble.com/GWt-Openlayers-problem-GOOGLE-layer-appears-in-left-corner-tp4619582p4640966.html
