[OpenLayers-Users] WMS Map request
Kalyan Kamepalli
kalyan.kamepalli at gmail.com
Tue Jul 6 03:06:39 EDT 2010
I Solved it.
It's the problem with resolution. I changed the resolution from 1000 to
8000000 and that solved my problem. Is there a start/begin document for Open
Layers ? other than that example developments ??
On Tue, Jul 6, 2010 at 4:02 PM, Bart van den Eijnden (OSGIS) <
bartvde at osgis.nl> wrote:
> Hi,
> use singleTile: true and ratio: 1 in your layer options.
> Best regards,
> Bart
> > Hi Group,
> > I am trying to configure my WMS service with OpenLayers. My script looks
> > below
> > <script type="text/javascript">
> > //var map = new OpenLayers.Map('map',{maxResolution: 1000} );
> > var map = new OpenLayers.Map('map', {
> > maxExtent: new OpenLayers.Bounds(
> > -638480920.244,-188017611.367,665489491.580,1019789790.73),
> maxResolution:
> > 500 } );
> > var wmsURL = "
> > http://localhost:8080/gss/ogc?version=1.3.0&crs=sw:nsw_trans_mercator_mm
> > var myLayer = new OpenLayers.Layer.WMS( 'CE SL' , wmsURL , { layers:
> > 'background', styles: 'Default' } , { buffer: 1 , isBaseLayer: true } );
> > map.addLayer( myLayer );
> > map.zoomToMaxExtent();
> > </script>
> > It should actually send only one WMS request for the first time and then
> > act
> > according to uses operations like Pan , Zoom. But, that is not how it's
> > working. Everytime when I open this html file, it's sending 48 WMS
> > requests
> > and creating 48 image files in the resources folder and none of these
> > images
> > are turned up on the browser. Also, surprisingly all those 48 images are
> > empty with just white background.
> > Does any one what the problem is ?
> > Thanks,
> > Kalyan
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100706/02b4e2f0/attachment.html
