[OpenLayers-Users] MergeNewParams / redraw
Sascha M.
olaiya at arcor.de
Thu Jul 8 13:04:33 EDT 2010
Hi all,
I use:
- Openlayers 2.9.1
- GeoExt 0.7
- GeoServer 1.7.7
I want:
... to use a new SLD for my WMS-Layer.
The Layer is inside a LayerTree, a map and inside a Legend-Panel.
Problem:
I use the below code to update the SLD. The Legend-Graphic inside the
Legend-Panel accepts the new Style. The map doesn't accept the new style.
There is still the old style for the layer.
Code:
node.layer.mergeNewParams(
format : "image/png",
transparent : "true",
sld_body : sld
isBaseLayer : false,
unsupportedBrowsers : []
node.layer.redraw(true);
I found a lot posts about this topic. But nothings helped. Now, I'm not sure
to use mergeNewParams() the right way. Can I use this Method with
OpenLayers.Layer.WMS? Is there anything else I have to consider?
Thanks
Sascha
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MergeNewParams-redraw-tp5271050p5271050.html
