[OpenLayers-Users] openlayers and css error
Rossko
rossko at culzean.clara.co.uk
Sat Jul 10 17:32:26 EDT 2010
example:http://www.myethiopia.org/KililisandWoredasandZones/Kilil/Kilil.html
(shouldn't take more than 14 sec :))
Took three minutes and a "script running slow" prompt in IE ; in Firefox
about the same time and eight prompts. Not all PCs or browsers are alike.
The javascript file here is "only" 2Mb ... you've got to simplify. Just
taking out whitespace would help. Do you really need both google and yahoo
maps? Can you simplify the projections in use? Would another data format
work quicker than WKT? Do your points really need to be specified to better
than 1mm precision?
Seperating the data from the script is good practice, and should allow you
to at least show some kind of map while all the crunching is going on,
instead of the nothingness that currently greets visitors to your page.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/openlayers-and-css-error-tp5271709p5278670.html
