[OpenLayers-Users] Confused about items on a map.
christopher.schmidt at nokia.com
Thu Jul 15 10:32:52 EDT 2010
On Jul 15, 2010, at 10:29 AM, ext ulao wrote:
> hey, thx. I think my bigger issue is this..
> http://dev.openlayers.org/releases/OpenLayers-2.9/doc/apidocs/files/OpenLayers/Feature-js.html
> vs
> http://dev.openlayers.org/docs/files/OpenLayers/Feature-js.html
> the top is a stripped down no option version of the bottom, what am I
> missing here? The second link has what i would have expected. so what the
> first link all about?
"There are two types of properties/methods in the OpenLayers code: One set is the set of API Methods and properties. There are also additional internal properties which are not exposed to the API. Javascript does not have private members, so there is no technical limitation to using these non-documented methods in Application code. However, while we make every effort not to change APIs between releases, methods and properties which are not explicitly declared as API Methods may change in minor releases.
The documentation above only includes the API Methods. Full developer/internal library documentation is also available below, but methods which are not available in the API documentation above can not be depended upon to stay the same between releases. If you use methods included in these docs, you may have to make modifications in your application code to run between minor releases of OpenLayers."
-- http://trac.openlayers.org/wiki/Documentation
> So SelectFeature will get me my reference, can I get it during
> construction.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Confused-about-items-on-a-map-tp5297445p5297646.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Regards,
Christopher Schmidt
Nokia
