[OpenLayers-Users] SphericalMercator and SRS aliases epsg:900913,
epsg:3857, epsg:3785, epsg:102113
Anne Blankert
anne.blankert at geodan.nl
Mon Jul 19 06:14:51 EDT 2010
Hello list,
OpenStreetMap and also some popular commercial mapservices (google,
bing, yahoo) are using the so called sphericalmercator projection.
OpenLayers has built-in support for this type of layer, inherited from
OpenLayers.Layer.SphericalMercator.
If you use a sphericalmercator layer as a baselayer, you may want to
combine this with other layers. By default, the openlayers
sphericalmercator baselayer uses SRS projection-code 'EPSG:900913' . So,
if you try to open an overlay, the overlay layer will be called with
parameter SRS=EPSG:900913.
EPSG Code 900913 happens to be a bogus code, based on the word 'google'.
Perhaps due to the resemblance of '900913' and 'google' or due to other
reasons, there are now several other codes in use for the same projection:
EPSG:3857
EPSG:3785 <= maybe because of a typo by someone somewhere?
EPSG:102113
Some map-services have stopped supporting SRS=EPSG:900913 and this
raises a problem for openlayers sphericalmercator users. Instead of
displaying a map, these mapservices will respond with something like 'no
support for EPSG:900913'.
The problem of overlaying sphericalmercator layers that do not support
epsg:900913 can be (partly) solved as follows:
Override the default srs code for sphericalmercator layers by explicitly
resetting the projection before adding the layer to a map:
var osmLayer = new OpenLayers.Layer.OSM("OpenStreetMap"); // osmlayer is
now sphericalmercator with default epsg:900913
osmLayer.projection = new OpenLayers.Projection ("EPSG:3857"); //
osmlayer is now sphericalmercator with epsg:3857
map.addLayers ([osmLayer]);
Overlay layers will now be requested with SRS=ESPG:3857
However, resetting the code for the baselayer projection, causes trouble
for the controls for MousePosition and MeasureControl: distances and
coordinates are no longer presented in the correct projection.
I solved this by adding the following lines of code to file
lib\OpenLayers\Layer\SphericalMercator.js
OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:3857",
OpenLayers.Layer.SphericalMercator.projectForward);
OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:102113",
OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:3785",
OpenLayers.Projection.addTransform("EPSG:3857", "EPSG:4326",
OpenLayers.Layer.SphericalMercator.projectInverse);
OpenLayers.Projection.addTransform("EPSG:102113", "EPSG:4326",
OpenLayers.Projection.addTransform("EPSG:3785", "EPSG:4326",
Questions:
- is this the way to support aliases for 900913 and support
MousePosition and MeasureControl at the same time?
- if yes, shouldn't the above lines be part of the standard OpenLayers
distribution?
Anne Blankert
