[OpenLayers-Users] Empty Base Layer?
Lennox Antoine
lxnyce at gmail.com
Mon Jul 19 19:57:49 EDT 2010
When you intialize your map, pass it a "restrictedExtent" so that it will
only show your area of interest. See this example :
http://openlayers.org/dev/examples/restricted-extent.html
Also, it should be possible to use one of your vector layers as a basemap,
rather than creating a layer that does nothing.
Lennox
On Mon, Jul 19, 2010 at 7:36 PM, Mike Purvis <mike at uwmike.com> wrote:
> Well, I'm only displaying blank tiles on that layer, but there are a number
> of items in the vector layer above—I would like to restrict the viewport to
> the region containing these items.
> M.
> On Mon, Jul 19, 2010 at 6:04 PM, Lennox Antoine <lxnyce at gmail.com> wrote:
>> What effect are you referring to? Why do you care to restrict the bounds
>> of the layer if you're just displaying blank tiles?
>> Lennox
>> On Mon, Jul 19, 2010 at 5:19 PM, Mike Purvis <mike at uwmike.com> wrote:
>>> In both those cases I get global coordinates, though, don't I?
>>> My Image layer is like so:
>>> baseLayer = new OpenLayers.Layer.Image( "Image",
>>> "/static/img/gridmap.png",
>>> new OpenLayers.Bounds(0, 0, 3, 3),
>>> new OpenLayers.Size(600, 600),
>>> It's a 600x600 image, and the coordinate system of the map scales that
>>> from 0..3. Is there a straightforward way to get this effect with either of
>>> the two above solutions?
>>> Thanks.
>>> On Mon, Jul 19, 2010 at 5:10 PM, BMcBride <bmcbride at chacompanies.com>wrote:
>>>> var nobase = new OpenLayers.Layer("No Basemap",{isBaseLayer: true,
>>>> 'displayInLayerSwitcher': true});
>>>> Bryan R. McBride, GISP
>>>> http://www.bryanmcbride.com bryanmcbride.com
>>>> http://geoserving.net/ geoserving.net
>>>> View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/Empty-Base-Layer-tp5314013p5314066.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> http://uwmike.com
> http://uwmike.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100719/ff28e1f3/attachment.html
