[OpenLayers-Users] Layers/OverLays are not Transparent in IE
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Thu Jul 22 22:02:58 EDT 2010
My Web Service doesn't accept 'gif' value for image format. However, it
accepts another parameter called 'image_transparency' with values of either
'rgb' or 'argb'. Setting it to 'argb' solved the problem. Now, the
transparency of the outer layers working perfect with IE.
Now the problem is solved.
Thank you all for your responses.
Cheers,
Kalyan
On Thu, Jul 22, 2010 at 10:50 PM, BMcBride <bmcbride at chacompanies.com>wrote:
> Try requesting the image in gif format and see if transparency works in IE.
> Bryan R. McBride, GISP
> http://www.bryanmcbride.com bryanmcbride.com
> http://geoserving.net/ geoserving.net
> http://osgeo-org.1803224.n2.nabble.com/Layers-OverLays-are-not-Transparent-in-IE-tp5324019p5325176.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100723/23103e9e/attachment.html
