[OpenLayers-Users] SVG
Thomas PAPIN
thomas.papin at gmail.com
Tue Jul 27 05:49:53 EDT 2010
Hi Chris,
*> Then I recommend doing more research into how browsers work. :)*
I am quite sure my question is stupid ! But look to this simple code:
<?xml version="1.0"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "
http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<body>
<h1>Just a Rectangle</h1>
<svg
xmlns:svg="http://www.w3.org/2000/svg" xmlns="http://www.w3.org/2000/svg"
version="1.0" width="150" height="150" id="svg1341">
<rect width="90" height="90" x="30" y="30"
style="fill:#0000ff;fill-opacity:0.75;stroke:#000000;stroke-width:1px"
id="rect1353" />
</svg>
</body>
</html>
if this code is in a file with filename
- test.xhtml it's working
- test.html nothing displayed.
My current understanding is that if you want to add SVG to a HTML page, you
need to use createElementNS and NS = "http://www.w3.org/2000/svg"
in this case it will works even if the page is declared a HTML and not
XHTML.
You cannot insert SVG in a HTML page except in the SVG is added via
javascript
Is that correct ?
>I'm not sure I understand what you're doing. Can you share
> the OpenLayers JavaScript you are attempting to use?*
I finally manage to realize what I wanted. Maybe there is a better way.
My Use case:
In a KML file, I have two polygons. One is a mask, the second is the polygon
I want to clip
How I did:
To realize that I want to use the "clipPath" of SVG
First I need to add <defs><clipPath>mypolygonmask</clipPath><defs> to the
SVG renderer
Then I need to add clip-path attribut to my second polygon.
GMLlayer.events.register("loadend", GMLlayer, function() {
id = this.id;
id = id.replace(/\./g, '\\.');
//Add <defs> to SVG Renderer when the layer is
loaded
var defs = document.createElementNS("
http://www.w3.org/2000/svg", "defs");
var clipPath = document.createElementNS("
http://www.w3.org/2000/svg", "clipPath");
clipPath.setAttribute("id","decoupe");
var path = document.createElementNS("
http://www.w3.org/2000/svg", "path");
path.setAttribute("id","decoupepath");
features = this.features;
//Mask polygon is identified in the KML by name =
Mask
for(i=0;i<features.length;i++) {
if (features[i].attributes.name == "Mask") {
maskid = features[i].geometry.id;
maskid = maskid.replace(/\./g, '\\.');
pathO = $("#"+maskid).get(0);
#Path0 can be NULL, if the polygon mask is
not in the current viewbox
if (pathO)
path.setAttribute("d",pathO.getAttribute('d'));
continue;
clipPath.appendChild(path);
defs.appendChild(clipPath);
root = $("#"+id+"_svgRoot").get(0);
root.appendChild(defs);
# Add clippath attributes
$("#"+id+"_root").attr('clip-path',"url(#decoupe)");
//Any time the zoom is changed, the polygon is the SVG are
regenerated by openlayers, so the mask should be updated too
map.events.register("zoomend", GMLlayer, function(e) {
id = this.id;
//alert(maskid);
//alert($("#"+id+"_vroot
path:first").attr('id'));
pathClip = $("#decoupepath").get(0);
if ((pathClip)&&(pathO))
pathClip.setAttribute("d",pathO.getAttribute('d'));
continue;
2010/7/22 <christopher.schmidt at nokia.com>
> On Jul 22, 2010, at 3:59 AM, ext Thomas PAPIN wrote:
> > Hello,
> > I am trying to understand how the SVG renderer works.
> > What I am not understanding is that there is SVG inline even if my
> webpage is declared has HTML and not XHTML.
> > I am not able to understand how this is possible.
> > I am looking to that, because in the same time I try to use a clipPath
> between two polygons in the SVG render of a layer.
> > Even if I add a valid SVG, nothing is displayed.
> -- Chris
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100727/3326ab97/attachment.html
