[OpenLayers-Users] SphericalMercator and SRS aliases
epsg:900913, epsg:3857, epsg:3785, epsg:102113
Andreas Hocevar
ahocevar at opengeo.org
Tue Jul 27 08:29:31 EDT 2010
On Jul 27, 2010, at 14:25 , Arnd Wippermann wrote:
> Hi,
> That way you have to set the SRS in the params and the projection in the
> options.
If you have set a projection in the map options, you don't have to set it again on the layer.
Regards,
Andreas.
> I would think, it's better, the params get the projection from the map and
> if you want to overwrite the SRS use projection or projectionAlias in the
> options.
> That way you have only one change not two.
> Also I think, it's better, that one could only overwrite WMS params, which
> OpenLayers couldn't set by itself like version, layers etc.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: Andreas Hocevar [mailto:ahocevar at opengeo.org]
> Gesendet: Dienstag, 27. Juli 2010 09:05
> An: Arnd Wippermann
> Cc: 'Anne Blankert'; users at openlayers.org
> Betreff: Re: [OpenLayers-Users] SphericalMercator and SRS aliases
> Please have a look at http://trac.openlayers.org/ticket/2756 and provide
> feedback.
> Regards,
> Andreas.
> On Jul 26, 2010, at 14:13 , Arnd Wippermann wrote:
>> Hi Anne,
>> I agree, something like 'projectionAlias' is better to understand than
>> projection.
>> Arnd
>> Von: users-bounces at openlayers.org
>> [mailto:users-bounces at openlayers.org] Im Auftrag von Anne Blankert
>> Gesendet: Montag, 26. Juli 2010 00:02
>> An: users at openlayers.org
>> Hello Arnd,
>> An option named "sphericalmercatoralias" is indeed very specific to
>> sphericalmercator.
>> Maybe, an option named "projection" is not specific enough. Users
>> could think that such an option would somehow magically allow
>> reprojecting the overlay projection to the map projection. Things
>> would get mixed up, when sending bounding box coordinates using the wrong
> projection.
>> So maybe an option named "projectionalias" would be a better name than
>> "sphericalmercatoralias" or "projection"?
>> "projectionalias" stresses the fact that the projection itself should
>> not be different, just the code that is being used for the projection.
>> Anne
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/SphericalMercator-and-SRS-alias
>> es-eps g-900913-epsg-3857-epsg-3785-epsg-102113-tp5311417p5336039.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Andreas Hocevar
