[OpenLayers-Users] International date line and bounds
[SEC=UNCLASSIFIED]
David Zwarg
dzwarg+ol at azavea.com
Tue Jul 27 17:03:06 EDT 2010
Hello Piero,
You may have to adjust the coordinates to 'saddle' the IDL. For example, a
rectangle with the coordinates:
170, 10 -------+------ -170, 10
| IDL |
170, -10 ------+------ -170, -10
May extend the "wrong way" around the globe. If you manually adjust the
coordinates so they are all on the same side of the IDL, it will probably
work:
-190, 10 -------------- -170, 10
-190, -10 ------------- -170, -10
or:
170, 10 -------------- 190, 10
170, -10 ------------- 190, -10
Notice that in the last two examples, the X coordinates are either all
positive, or all negative. I have found this to work quite well; you can
even extend this to keep adding features to 'globes' that are beyond -180.
There is one thing to be wary of, though: when you do cross the date line,
the entire geometry will jump to the left or right by 1 globe
circumference. I don't have a workaround for that, but you can trick OL by
adding features to the neighboring 'globes'.
-z
On Tue, Jul 27, 2010 at 7:03 AM, Piero Campa <piero.campa at gmail.com> wrote:
> Hi all,
> I'm drawing polygon over a Google base layer.
> Even though I set wrapDateLine to true in the Google base layer, the
Vector
> layer AND the temporary layer created by the RegularPolygon handler, still
> when I draw a polygon I cannot cross the IDL.
> Any idea guys?
> Thank you,
> Piero
http://osgeo-org.1803224.n2.nabble.com/International-date-line-and-bounds-tp2541265p5341698.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
David Zwarg
Software Developer at Azavea (formerly Avencia)
(215) 701-7718
dzwarg at azavea.com
http://www.azavea.com/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100727/ec7547b1/attachment.html
