[OpenLayers-Users] International date line and bounds
[SEC=UNCLASSIFIED]
David Zwarg
dzwarg+ol at azavea.com
Wed Jul 28 09:41:50 EDT 2010
Hello Piero,
This is my understanding of how wrapDateLine works:
The wrapDateLine property is used by tile layers when determining which
tiles to display. If your layer contains "wrapDateLine: true", the layer
adjusts it's tile coordinates if the IDL is in the map viewport. If your
layer contains "wrapDateLine: false", the layer will not adjust tile
coordinates. I think that this does not apply to vector layers, only tiled
layers.
I have not had success with setting maxExtent to include multiple globes,
either. I have only had success setting the map maxExtent to a smaller
extent that the globe, and using restrictedExtent to constrain the map
navigation within that extent.
-z
On Wed, Jul 28, 2010 at 4:01 AM, Piero Campa <piero.campa at gmail.com> wrote:
> Thank you David,
> ok so: isn't it the behaviour of a layer with wrapDateLine = false, i.e.
> the
> default behaviour?
> Moreover, I was trying to see the effect of maxExtent property of the map
> (I
> think I have to set it wider to just 1 globe, so to go beyond the IDL), but
> nothing changes, even for very small maxExtents.
> ...So what does the maxExtent stand for?
> Piero
> http://osgeo-org.1803224.n2.nabble.com/International-date-line-and-bounds-tp2541265p5345342.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100728/e40dcd6c/attachment.html
