[OpenLayers-Users] Noob - Serving Tiles Without a 'Server'
Arnie Shore
ashore3 at verizon.net
Sat Jun 5 09:45:57 EDT 2010
Hello all.
I'm using the script at
http://wiki.openstreetmap.org/wiki/OpenLayers_Simple_Example:
I have a set of OSM tiles under my 'tiles'directory - named correctly, I
believe. (e.g., '13/2352/3131.png') - on my web server's /osm/tiles
directory.
I'm trying to serve these up with the following lines (using the base
example script noted above) , which gets me the empty pink:
layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://127.0.0.1/osm/tiles/");
map.addLayer(layer);
which I've adapted from the following lines in the simple example, which
works correctly:
var my_map_obj = new OpenLayers.Layer.OSM();
map.addLayer(my_map_obj);
My question is whether something this lightweight can really work? (I'd
like to RTFM on this, but I haven't yet found the M to R.) If yes, what
do I need to do to make it work?
Thanks for any help on this.
AS
