[OpenLayers-Users] Does anyone have the projection definitions
for all EPSG codes in Proj4js format?
Vadim Bokin
vbokin at gmail.com
Sun Jun 6 17:16:59 EDT 2010
Thanks for all the advice. Since there's nothing readily available, I
downloaded all the EPSG codes below 33,000 with a little wget script.
I'm making the zip (attached) available to all in case someone needs
something similar. Zip file contains 4056 files/definitions in the
following ranges:
ESPG 2000_to_5821
ESPG 7400_to_7500
ESPG 20000_to_32766
All invalid, or 0kb, definitions were removed. So all definitions in the
zip are a few bytes and 1 line each. Zip is small, but does contain 4k+
files, so be patient during unzip. If you need them all in one file you
could "cat" them all together.
My count of 4056 is less than SR's web count 4362 right now because I didn't
get any definitions above 32,766.
Thanks,
-Vadim
http://osgeo-org.1803224.n2.nabble.com/file/n5146690/ESPG_2000_to_5821__7400_to_7500__20000_to_32766.zip
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Does-anyone-have-the-projection-definitions-for-all-EPSG-codes-in-Proj4js-format-tp5141431p5146690.html
