[OpenLayers-Users] Does anyone have the projection definitions
for all EPSG codes in Proj4js format?
Thomas Gratier
osgeo.mailinglist at gmail.com
Sun Jun 6 15:37:26 EDT 2010
Hello,
Sorry a small mistake, replace
http://spatialreference.org/ref/epsg/2154/proj4js/ by
http://spatialreference.org/ref/epsg/4326/proj4js/<http://spatialreference.org/ref/epsg/4326/proj4js/>for
comparing with other adress
So the original message corrected below
> You can make think easier using spatial_ref_sys table of a posgresql
> database with postgis enabled.
> If you look, there's a column call proj4text in this table.
> If you compare http://spatialreference.org/ref/epsg/4326/proj4js/<http://spatialreference.org/ref/epsg/4326/proj4js/>,
> http://spatialreference.org/ref/epsg/4326/proj4/ and "+proj=longlat
> +ellps=WGS84 +datum=WGS84 +no_defs" from spatial_ref_sys table, you see
> proj4 value = proj4text spatial_ref_sys table and
> that proj4 and proj4js are near the same, except some differences.
> You can make all proj4js code using the PHP code below. I suppose you have
> a Postgis database ready on your computer and you know how to execute php
> code.
> <?php
> $conn_string = "host=localhost port=5432
> dbname=mydatabase_with_postgis_activated user=my_user password=my_password";
> $link = pg_connect($conn_string) or die("Could not connect");
> $start_epsg = 'Proj4js.defs["EPSG:';
> $end_epsg_start_proj4js = '"] = "';
> $end_proj4js ='";';
> $select_epsg = pg_query("SELECT srid,trim(proj4text) as proj4text from
> spatial_ref_sys");
> //Uncomment if you want to make a particular file for proj4js file
> depending on defined epsgvalues
> $epsgvalues = "4326,2154";
> spatial_ref_sys WHERE srid IN(".$epsgvalues.")");
> $stringData="";
> while($proj4_code = pg_fetch_array($select_epsg)) {
> //To view result
> echo
> $start_epsg.$proj4_code["srid"].$end_epsg_start_proj4js.$proj4_code["proj4text"].$end_proj4js.'<br/>';
> //To prepare content for writing result
> $stringData.=$start_epsg.$proj4_code["srid"].$end_epsg_start_proj4js.$proj4_code["proj4text"].$end_proj4js."\r\n";
> $myFile = "epsg.js";
> $fh = fopen($myFile, 'w') or die("can't open file");
> fwrite($fh, $stringData);
> fclose($fh);
> Regards
> ThomasG
> GIS specialist
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100606/52df8b6d/attachment.html
