[OpenLayers-Users] Does anyone have the projection definitions
	for all EPSG codes in Proj4js format?
    Thomas Gratier
    osgeo.mailinglist at gmail.com
    Sun Jun  6 15:32:20 EDT 2010
Hello,
You can make think easier using spatial_ref_sys table of a posgresql
database with postgis enabled.
If you look, there's a column call proj4text in this table.
If you compare http://spatialreference.org/ref/epsg/2154/proj4js/ ,
http://spatialreference.org/ref/epsg/4326/proj4/ and "+proj=longlat
+ellps=WGS84 +datum=WGS84 +no_defs" from spatial_ref_sys table, you see
proj4 value = proj4text spatial_ref_sys table and
that proj4 and proj4js are near the same, except some differences.
You can make all proj4js code using the PHP code below. I suppose you have a
Postgis database ready on your computer and you know how to execute php
code.
<?php
$conn_string = "host=localhost port=5432
dbname=mydatabase_with_postgis_activated user=my_user password=my_password";
$link = pg_connect($conn_string) or die("Could not connect");
$start_epsg = 'Proj4js.defs["EPSG:';
$end_epsg_start_proj4js = '"] = "';
$end_proj4js ='";';
$select_epsg = pg_query("SELECT srid,trim(proj4text) as proj4text from
spatial_ref_sys");
//Uncomment if you want to make a particular file for proj4js file depending
on defined epsgvalues
$epsgvalues = "4326,2154";
spatial_ref_sys WHERE srid IN(".$epsgvalues.")");
$stringData="";
while($proj4_code = pg_fetch_array($select_epsg)) {
//To view result
echo
$start_epsg.$proj4_code["srid"].$end_epsg_start_proj4js.$proj4_code["proj4text"].$end_proj4js.'<br/>';
//To prepare content for writing result
$stringData.=$start_epsg.$proj4_code["srid"].$end_epsg_start_proj4js.$proj4_code["proj4text"].$end_proj4js."\r\n";
$myFile = "epsg.js";
$fh = fopen($myFile, 'w') or die("can't open file");
fwrite($fh, $stringData);
fclose($fh);
Regards
ThomasG
GIS specialist
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100606/5164a7c4/attachment.html
