[OpenLayers-Users] Google Maps using api 3
Rohan Parkes
rohan.parkes at pelicancorp.com
Wed Jun 23 02:24:25 EDT 2010
I was trying the patch. It seems to break for me in FF 3+ - overlays and
controls disappear. They appear briefly sometimes when I interact with the
map.
Moreover, I noticed also that my WMS overlays developed an "elastic" quality
in all browsers - when panning, they would drag slightly behind the base map
and then catch up after the pan was complete.
However, what I actually wanted the 3 API for was for Styled Map Types. I
was trying to adapt the Google code example:
var stylez = [{
featureType: "road.local",
elementType: "geometry",
stylers: [{
hue: "#00ff00"
saturation:100
map = new google.maps.Map(document.getElementById("map_canvas"),
mapOptions);
var styledMapOptions = {
map: map,
var jayzMapType = new google.maps.StyledMapType(stylez,styledMapOptions);
map.mapTypes.set('hiphop', jayzMapType);
map.setMapTypeId('hiphop');
by creating a Google 3 layer, and getting a reference to the actual Google
map object using
lyrBaseGoogleStreet.mapObject
and using that to apply the styles. i.e. from the above, I was using
lyrBaseGoogleStreet.mapObject.mapTypes.set('hiphop', jayzMapType);
Again, I kept finding that the style would appear momentarily when the map
loaded, then vanish, leaving the standard Google base map. This happened in
all browsers.
Rohan Parkes
PelicanCorp
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of christopher.schmidt at nokia.com
Sent: Thursday, 17 June 2010 00:32
To: woodbri at swoodbridge.com
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Google Maps using api 3
On Jun 16, 2010, at 10:27 AM, ext Stephen Woodbridge wrote:
> Hi devs,
> FYI:
> It looks like google has a fix in place to disable animation on
> setCenter, is:
> http://code.google.com/p/gmaps-api-issues/issues/detail?id=2346
> I think that this was the blocking item for implementing a Google layer
> provider in OL using the Gmaps 3 api.
> I might have misunderstood, but you might be interested in this change
> if you have not been tracking the bug.
I believe Tim has already noted this in the corresponding trac ticket:
http://trac.openlayers.org/ticket/2493#comment:6
Regards,
Christopher Schmidt
Nokia
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
