[OpenLayers-Users] How to SetUp Open Layers for an XML/WMS Service
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Wed Jun 30 02:08:18 EDT 2010
On Jun 30, 2010, at 1:58 AM, ext Kalyan Kamepalli wrote:
> Yahoo !! I made some progress,
> I actually didn’t know that I have to create a layer for the map object. I now created one later and added it to map object. Excellent. It worked. I got my map. But, I am not happy with the quality/resolution of the map. I then set the maxResolution property of the map from 0.73 to 1. That didn’t help me either. Is there anything else I should do to improve it’s quality ? The same WMS direct call results in a high quality map from my server.
Remove the width, height, and bbox from your URL. then change your map creation to:
 Map('map', {
	maxExtent: new OpenLayers.Bounds(545130525,258147752,546437807,259455034)
        maxResolution: 5000
Your Layer URL should then look like:
  "http://localhost:8080/gss/ogc?version=1.3.0&crs=sw:uk_british_national_grid_mm"
Does the behavior improve?
-- Chris
> Any help is greatly appreciated.
> Thanks,
> Kalyan
> On Wed, Jun 30, 2010 at 1:41 PM, Kalyan Kamepalli <kalyan.kamepalli at gmail.com> wrote:
> Hi group,
> I do have a WMS service with my product, I am actually trying to use Smallworld Geospatial Server with WMS service. I just found one example using WMS service and trying to edit it to work with my service call. I changed the script section as follows
> <script type="text/javascript">
>             var map = new OpenLayers.Map('map',{maxResolution: 0.703125} );
>             var wmscURL = [
>                         "http://localhost:8080/gss/ogc?request=GetMap&service=WMS&version=1.3.0&width=600&height=600&format=image/jpeg&bbox=545130525,258147752,546437807,259455034&crs=sw:uk_british_national_grid_mm"
>                                                 //"http://wmsc1.terrapages.net/getmap?",
>                                                 //"http://wmsc2.terrapages.net/getmap?",
>                                                 //"http://wmsc3.terrapages.net/getmap?",
>                                                 //"http://wmsc4.terrapages.net/getmap?"
>             //var terrapagesStreetLayer = new OpenLayers.Layer.WMS( 'TerraPages Street',wmscURL, {layers: 'UnprojectedStreet', format: 'image/jpeg' }, {buffer: 1, isBaseLayer: true} );
>             //map.addLayer(terrapagesStreetLayer);
>             map.zoomToMaxExtent();
> </script>
> As I don’t want to display any other map, I commented those 4 map requests and included my request. But, It doesn’t give me any map. What could be reason for that ??
> If I use the same URL directly from a browser, I could see a map.  Is there something I am missing ? or is it not the way to call a map service ??
> Thanks,
> Kalyan
> On Tue, Jun 29, 2010 at 5:05 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> have a look thru the examples
> http://www.openlayers.org/dev/examples/
> that should be a good starting point, use view source to see how things are done
> z
> On 29 June 2010 13:44, Kalyan Kamepalli <kalyan.kamepalli at gmail.com> wrote:
> > Hello Everyone,
> > I am new to Java Script and thus Open Layers. I have an application server
> > that provides a map service and many other services like select, zoom in
> > zoom out.I wanted to map them on to Open layers and finally embed open
> > layers on to a website. The map service is an XML based and it generates an
> > XML response.I also have WMS services that respond in WMS format.
> > Could someone share me the procedure to make the above process to work
> > please. I know a bit of Java Script. Like how it works and how to code in it
> > and the function,Object structure of it. But, I never worked on it.
> > Regards,
> > Kalyan
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> <ATT00001..txt>
Regards,
Christopher Schmidt
Nokia
