[OpenLayers-Users] which is the best way to display a set of
points coming from database?
BMcBride
bmcbride at chacompanies.com
Wed Sep 1 10:01:52 EDT 2010
Hey Alberto,
I've had luck using PHP with a SELECT statement on a MySQL database to write
a KML file for use in OpenLayers. As long as your query returns a
relatively small subset of features (<500) and your users have a snappy
connection with a decent browser, you should be OK using this method.
Fortunately you are returning point features with a single set of coordinate
pairs, as opposed to complex polygons! A benefit of using KML is that you
can also let the user download the results in a fairly common and readily
usable GIS format without having to write any additional code. If you are
interested I can post my MySQL -> KML PHP script.
Best of luck!
BRYAN
Bryan R. McBride, GISP
http://www.bryanmcbride.com bryanmcbride.com
http://geoserving.net/ geoserving.net
View this message in context: http://osgeo-org.1803224.n2.nabble.com/which-is-the-best-way-to-display-a-set-of-points-coming-from-database-tp5482933p5487113.html
