[OpenLayers-Users] How to modify feature's attribute data ?
Xurxo Mendez
sonxurxo at gmail.com
Thu Apr 7 03:41:28 EDT 2011
To be able to store data in GeoServer you must use WFS-T (WFS transactional,
it's a profile of the OGC's WFS standard
http://www.opengeospatial.org/standards/wfs). OpenLayers provides support
for that, see
http://openlayers.org/dev/examples/wfs-protocol-transactions.html (take a
look at the source, it's not about modifying attributes but
creating-modifying geometries, but it's the same problem).
In the downloaded package, in the examples folder, you can modify this same
example to make it work against your own GeoServer.
Best regards,
Xurxo Méndez Pérez
http://blog.sonxurxo.com
http://www.sonxurxo.com
2011/4/7 Mustafa646 <noorcs22 at gmail.com>
> I am developing application in OpenLayers and GeoServer. I have displayed a
> shapefile over Google Map. Now i want to change the attribute data of a
> polygon on clicking. I need, the changes should be made to the shapefile
> back at GeoServer as well. Is it possible ?, If yes, then How can i do this
> task. need any help by putting some example code/link or some good
> suggestion ? Best regards
> View this message in context: How to modify feature's attribute data ?<http://osgeo-org.1803224.n2.nabble.com/How-to-modify-feature-s-attribute-data-tp6248950p6248950.html>
> Sent from the OpenLayers Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Users-f1822463.html>at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110407/40301594/attachment.html
