[OpenLayers-Users] FramedCloud size with floating objects in the
contents
Tom Chance
tom at acrewoods.net
Wed Apr 13 09:11:23 EDT 2011
Hello,
I've been reading through various old emails where people have problems with
FramedCloud sizing, but I can't find a solution to this problem.
I am populating the FramedCloud in the usual way with some HTML contents:
https://github.com/tomchance/OpenEcoMaps/blob/master/www/script/oem.js#L104
That contents includes a div with a CSS property to float right.
In some popups the height of the images in the right-floating div is greater
than any text, and in those instances the cloud cuts the images off at the
bottom and shows a scrollbar thanks to the overflow property being set to
'auto'. For an example, click on this recycling symbol:
http://www.openecomaps.co.uk/map.php?pack=LDN&zoom=6&lon=-0.07191&lat=51.48017&layers=B000FTFFFFT
>From what I've read, the code that calculates the size of the cloud is a bit
tricky and it looks like it isn't dealing with the floating div properly.
Other popups with non-floating contents show up properly in a much larger
popup.
Can anyone help me to either:
1. Set the default height of the popup to be a bit bigger, or
2. Fix the popups so they size correctly?
Regards,
Tom Chance
http://tom.acrewoods.net http://twitter.com/tom_chance
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110413/dac87b2f/attachment.html
