[OpenLayers-Users] FramedCloud size with floating objects in the contents
acousmetre acousmetre at gmail.com
Wed Apr 13 14:56:52 EDT 2011
Hello,
I'm using setSize after various elements are loaded:
popup.setSize(new OpenLayers.Size(width, height))
hope that helps - you can see the setSize function used in context in
the source of this page:
www.rabeca.org/index.htm
cheers,
iain
On Wed, 2011-04-13 at 14:11 +0100, Tom Chance wrote:
> Hello,
> I've been reading through various old emails where people have
> problems with FramedCloud sizing, but I can't find a solution to this
> problem.
> I am populating the FramedCloud in the usual way with some HTML
> contents:
> https://github.com/tomchance/OpenEcoMaps/blob/master/www/script/oem.js#L104
> That contents includes a div with a CSS property to float right.
> In some popups the height of the images in the right-floating div is
> greater than any text, and in those instances the cloud cuts the
> images off at the bottom and shows a scrollbar thanks to the overflow
> property being set to 'auto'. For an example, click on this recycling
> symbol:
> http://www.openecomaps.co.uk/map.php?pack=LDN&zoom=6&lon=-0.07191&lat=51.48017&layers=B000FTFFFFT
> From what I've read, the code that calculates the size of the cloud is
> a bit tricky and it looks like it isn't dealing with the floating div
> properly. Other popups with non-floating contents show up properly in
> a much larger popup.
> Can anyone help me to either:
> 1. Set the default height of the popup to be a bit bigger, or
> 2. Fix the popups so they size correctly?
> Regards,
> Tom Chance
> http://tom.acrewoods.net   http://twitter.com/tom_chance
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
