[OpenLayers-Users] Re: A WMS layer as base layer
Andrés Maneiro amaneiro at icarto.es
Fri Apr 29 10:45:15 EDT 2011
Hi there, more info in case it's useful:
- the WMS layer is restricted on scale. The imagery are limited to
scales from 1:40.000 and highest (1:10.000 and so). Seem no have limit
on the higher scales, more than the resolution of the image.
best,
amaneiro
On 28/04/11 20:05, Andrés Maneiro wrote:
> Hello,
> I've configured my map to use 3 different base layers (open street map,
> google map & google hybrid) with success. Nevertheless, I'm struggling
> to get as base layer a plain WMS. The symptons are:
> - when the user changes the base layer, the boundingbox gets zoomed in
> (which no happens when I change between OSM and google for example).
> - when the user changes the base layer, it is displaced someway to the
> north, so the features have no rendered in the proper place.
> I guess it has something to do with the resolutions and scales, as
> discussed here: http://trac.osgeo.org/openlayers/wiki/SettingZoomLevels
> But I've tried several alternatives with no success. Just in case
> someone has the time to review it, here the WMS I'm trying to set as
> base layer:
> http://ideg.xunta.es/wms-orto/request.aspx?request=getcapabilities&service=WMS
> Some ideas/suggestions?
> best,
> amaneiro
