AW: [OpenLayers-Users] WMS-C/TMS and WMTS
Budschedl Harald Harald.Budschedl at ikt.linz.at
Wed Aug 3 04:43:08 EDT 2011
Andreas, thanks for the answer, but no, it's not GeoServer.
My question is still up: is it enough to have the geocache as files on the disk, to be acessible from OL? Or do I need some service providing those files for OL?
TIA
Harry
-----Ursprüngliche Nachricht-----
Von: Andreas Hocevar [mailto:ahocevar at opengeo.org]
Gesendet: Dienstag, 02. August 2011 14:44
An: Budschedl Harald
Cc: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] WMS-C/TMS and WMTS
if your WMS is GeoServer in a recent version, you already have GeoWebCache already. Just make sure that your map/baseLayer uses Web Mercator (e.g. EPSG:900913) as projection, and the maxExtent is set to the Web Mercator world bounds. Then, configure a WMS layer where you add
tiled: true
to the params (3rd constructor argument).
Make sure you have "Direct GWC integration" checked on the GeoWebCache configuration page in the GeoServer web admin UI.
Andreas.
On Aug 2, 2011, at 13:26 , Budschedl Harald wrote:
> Hi there
> The tiling systems which can be used by OL are becoming more and more and I need to get more into this theme. So a few question arise and I think I ask them here. Maybe some of you can help me a bit here:
> 1)      Do you need some kind of webserver/webservice to access the tiles? I mean, yes, I know you need i.e. a WMS to be cached off in order to PRODUCE the tiles, but do you need a webserver/service afterwards to access those tiles?
> 2)      I tried tilecache.org and geowebcache.org but one doesn't run under 64bit Win2008 server and the other doesn't work with floating values (i.e. Koordinates) that have a comma instead of a point as a delimiter. Descriptions and documentation of those tools are old and most of the time not accurate and for someone not too deeply involved into the world of webservers, the whole thing is a bit of a dread to get to run. The mailinglist of tilecache.org is not accessible anymore and the mailinglist for geowebcache.org is dead as well (1 posting a day).  Are there any other tools?
> TIA for any answers.
> Cya,
> Harry
> Diese Nachricht inklusive aller Anhänge kann vertrauliche
> Informationen enthalten. Sie ist ausschließlich für die adressierten
> Personen bestimmt. Das unerlaubte Kopieren sowie die unbefugte
> Weitergabe sind nicht gestattet. Sollten Sie nicht die richtige
> Adressatin/der richtige Adressat sein, vernichten Sie den gesamten
> Inhalt (§ 93 Abs. 4 Telekommunikationsgesetz 2003) und informieren Sie
> bitte sofort den/die Absender/in. Nähere Regelungen zur elektronischen
> Kommunikation mit der Stadt Linz finden Sie in den "Allgemeinen
> Hinweisen und Nutzungsbestimmungen betreffend das E-Government der
> Stadt Linz (e-linz)" (http://www.linz.at/images/AGB_egov_2008.pdf )
> IKT Linz GmbH, Firmenbuch des Landesgerichtes Linz ++
> Firmenbuch-Nummer: 321197z ++ UID-Nummer: ATU64636344 IKT Linz
> Infrastruktur GmbH, Firmenbuch des Landesgerichtes Linz ++
> Firmenbuch-Nummer: 321990s ++ UID-Nummer: ATU64664303
> A-4020 Linz, Gruberstraße 42, Tel. +43 732 7070 0, Fax: +43 732 7070
> 54 1555, office at ikt.linz.at, www.linz.at/ikt
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
Diese Nachricht inklusive aller Anhänge kann vertrauliche Informationen enthalten. Sie ist ausschließlich für die adressierten Personen bestimmt. Das unerlaubte Kopieren sowie die unbefugte Weitergabe sind nicht gestattet. Sollten Sie nicht die richtige Adressatin/der richtige Adressat sein, vernichten Sie den gesamten Inhalt (§ 93 Abs. 4 Telekommunikationsgesetz 2003) und informieren Sie bitte sofort den/die Absender/in. Nähere Regelungen zur elektronischen Kommunikation mit der Stadt Linz finden Sie in den "Allgemeinen Hinweisen und Nutzungsbestimmungen betreffend das E-Government der Stadt Linz (e-linz)" ( http://www.linz.at/images/AGB_egov_2008.pdf )
IKT Linz GmbH, Firmenbuch des Landesgerichtes Linz ++ Firmenbuch-Nummer: 321197z ++ UID-Nummer: ATU64636344
IKT Linz Infrastruktur GmbH,  Firmenbuch des Landesgerichtes Linz ++ Firmenbuch-Nummer: 321990s  ++ UID-Nummer: ATU64664303
A-4020 Linz, Gruberstraße 42, Tel. +43 732 7070 0, Fax: +43 732 7070 54 1555, office at ikt.linz.at, www.linz.at/ikt
