AW: [OpenLayers-Users] WMS-C/TMS and WMTS
Noli Sicad
nsicad at gmail.com
Wed Aug 3 06:02:00 EDT 2011
This is better description of Mapbox Tiles.
http://mbtiles.org/
It like it to work in Openlayers without a server (i.e file:// protocol)
Noli
On 8/3/11, Noli Sicad <nsicad at gmail.com> wrote:
> I wonder if we can make this XYZ works with mbTiles.
> https://github.com/mapbox/mbtiles-spec/issues/14
> Noli
> On 8/3/11, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Yes you can. Let's say you have a typical xyz directory structure, like
>> the
>> Mapnik OSM tiles. Then you could create a custom XYZ layer:
>> new OpenLayers.Layer.XYZ({
>> url: "file:///path/to/my/tiles/${z}/${x}/${y}.png"
>> Andreas.
>> On Aug 3, 2011, at 11:32 , Noli Sicad wrote:
>>>> it is enough to have the tiles in a folder structure on the disk. If
>>>> the
>>>> disk is on your local machine, you can even use file urls (file://). If
>>>> it's
>>>> on a server, the directory structure should be served by a plain HTTP
>>>> server
>>>> (e.g. Apache).
>>>> If the disk is on your local machine, you can even use file urls
>>>> (file://).
>>> Just to clarify this statement above, can use tile files without http
>>> or tile sever in OpenLayers?
>>> Any OL example for this tile files without the server?
>>> Thanks.
>>> Noli
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
