[OpenLayers-Users] Reprojecting map issue
Hugo
hfpmartins at gmail.com
Fri Aug 12 07:27:06 EDT 2011
Hello all,
I'm trying to reproject openlayers map according to the selected base layer.
So, when the app is loaded my map has the EPSG:900913 projection (so that i
can use OSM, google, etc). I have other base layers that are in the EPSG:
3763 projection and, when the user activate this layers the map will
automatically reproject itself to this new definition. I was able to
accomplish this however i have a small bug that i've not been able to
correct until the moment. After reprojecting i can't pan and if i make a
zoom it will go to a strange location (i think the zoom is still assuming
the old coordinates). After making the zoom i'm able to pan and zoom
normally.
The code i'm using:
function onBaseLayerChange(evtObj){
var mapProj, baseProj, map, newBase, reproject;
map = this;
newBase = evtObj.layer;
mapProj = (map.projection && map.projection instanceof
OpenLayers.Projection) ? map.projection : new
OpenLayers.Projection(map.projection);
baseProj = newBase.projection;
reproject = !(baseProj.equals(mapProj));
if (reproject) {
var center, maxExt;
center = map.getCenter().transform(mapProj, baseProj);
maxExt = newBase.maxExtent;
map.projection = baseProj;
map.resolutions = newBase.resolutions;
map.maxResolution = newBase.maxResolution;
map.minResolution = newBase.minResolution;
map.maxExtent = maxExt;
map.restrictedExtent = newBase.restrictedExtent;
map.setCenter(center);
I suppose i'm not setting some property... but which one?
Thanks in advance.
Cheers,
Hugo
Hugo Martins
LabNT - ISEGI UNL
Campus de Campolide
1070-312 Lisboa
N 38°43'56.84", W 9°9'35.74"
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110812/af655527/attachment.html
