[OpenLayers-Users] pgrouting using openlayers
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Aug 15 21:05:37 EDT 2011
On 8/15/2011 7:02 PM, Robert Sanson wrote:
> What happens when your click point for a start or end is not directly on
> a node? Does pgrouting snap the start/end points to the nearest vertex
> on the nearest road?
I take the start and end points and in PHP connect to the database and
snap it to the nearest edge like this:
$sql = "SELECT gid, source, target, the_geom,
distance(the_geom, setsrid(makepoint(".
$lonlat[0].",".$lonlat[1]."), 4326)) AS dist
FROM ".TABLE."
WHERE the_geom && expand(setsrid(makepoint(".
$lonlat[0].",".$lonlat[1]."),4326), ".$EXPAND.")
ORDER BY dist LIMIT 1";
You can write some simple functions in plpgsql like:
find_nearest_link_within_distance()
find_nearest_node_within_distance()
find_node_by_nearest_link_within_distance()
I have these on one database, but I can remember if I wrote these or
they are part of pgRouting as I try to encapsulate most code in simple
function calls so it is reusable.
-Steve
> Thanks,
> Robert
> >>> Stephen Woodbridge <woodbri at swoodbridge.com> 16/08/2011 6:43 a.m. >>>
> On 8/15/2011 1:57 PM, sushma wrote:
> > Hi Guys,
> > I want to implement pgrouting using openlayers .i.e to find shortest path
> > from building to another buildings.So if user clicks one building as
> a start
> > point and another as end point then it returns the shortest path between
> > those buildings. I am totally new to the openlayers.
> > So far i can display the map of road data and buildings from
> geoserver using
> > openlayers. Now i wanted to get on with click control. So need some
> > suggestion how can i get on with click control.
> Here is an example that I put together using mapserver for the maps,
> pgRouting and I use a small PHP program to handle the the Ajax requests
> to communicate between OpenLayers and pgRouting.
> http://tinyurl.com/3vnufmh
> -Steve
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> This email and any attachments are confidential and intended solely for
> the addressee(s). If you are not the intended recipient, please notify
> us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted
> Security. www.websense.com <http://www.websense.com/>
