[OpenLayers-Users] postgresql table to Geojson and diplay it
in openlayers
Glenn Mullett
gmullett at lidwala.com
Wed Aug 24 14:00:21 EDT 2011
Hi Javad
What geojson string is returned by the php? - is it correctly formatted?
>> $sql = "SELECT gid, ST_AsGeoJSON(the_geom) AS geojson,
length(the_geom) AS length FROM ".TABLE.""
I usually format my geojson with properties at this point already (in a
plpgsql function)...
the wrapper function I wrote for this:
CREATE OR REPLACE FUNCTION geojson_attrib(table_name character varying,
gid character varying, cs character varying, ce character varying,
schema_name character varying)
RETURNS SETOF character varying AS
$BODY$
select 'SELECT ''{' || $3 || '"geometry":'' ||
st_asgeojson(transform(the_geom, 900913),6) ||
'',"type":"Feature",' || $4 || '"properties":{'
|| array_to_string(ARRAY(
SELECT '"' || c.column_name || '":"''||coalesce("'|| c.column_name ||
'"::varchar,''null'')||''"'
FROM information_schema.columns As c
WHERE table_schema= $5 and table_name = $1
AND c.column_name NOT IN('gid', 'the_geom')
), ',') || '},"gid":"'' || gid || ''"}'' as v FROM ' || $5 || '.' ||
$1 || ' where gid in(' || $2 || ')' as v;
$BODY$
LANGUAGE sql VOLATILE
I use cs and ce to (comment start, comment end) remove geometries if I
only want json, so you can set them to: ''
To display in Openlayers you need to add a geojson reader:
//load the php result into variable str using an xmlhttprequest ( I use
Ext to do this)
//geojson reader
var geojson_format = new OpenLayers.Format.GeoJSON();
//create a vector layer
var vector_sites = new OpenLayers.Layer.Vector();
//add the vector to the ol map
map.addLayer(vector_sites);
// read the geojson string into the layer
vector_sites.addFeatures(geojson_format.read(str));
Alternatively you can use GeoExt and just load the php result into a
FeatureStore that you point to a vector layer
var store = new GeoExt.data.FeatureStore({
layer: vector_layer,
fields:fields,
proxy: new GeoExt.data.ProtocolProxy({
protocol: new OpenLayers.Protocol.HTTP({
url: store_url,
format: new OpenLayers.Format.GeoJSON()
autoLoad: true
Regards
Glenn Mullett
BTech(Nature Cons) PGDip(UNIGIS)
H.O.D. GIS
Lidwala Consulting Engineers
email:gmullett at lidwala.com
___________________________________________________________________________________________________________________________________________________
On Wed, 2011-08-24 at 19:32 +0200, javad sadidi wrote:
> hi
> I have a table in postgresql that it has topology and I want to
> display it as line in openlayers.
> I use php to connect and convert my data to Geojson. this the
> codes.but I can not get the result.who can help me.where is wrong in
> my codes,this is the code.
> <?php
> // Database connection settings
> define("PG_DB" , "tehran");
> define("PG_HOST", "localhost");
> define("PG_USER", "postgres");
> define("PG_PORT", "5432");
> define("TABLE", "close");
> <?php
> // Connect to database
> $dbcon = pg_connect("dbname=".PG_DB." host=".PG_HOST."
> user=".PG_USER);
> // Perform database query
> $query = pg_query($dbcon,$sql);
> <?php
> // Return route as GeoJSON
> $geojson = array(
> 'type' => 'FeatureCollection',
> 'features' => array()
> // Add edges to GeoJSON array
> while($edge=pg_fetch_assoc($query)) {
> $feature = array(
> 'type' => 'Feature',
> 'geometry' => json_decode($edge['geojson'], true),
> 'crs' => array(
> 'type' => 'EPSG',
> 'properties' => array('code' => '4326')
> 'id' => $edge['id'],
> 'length' => $edge['length']
> // Add feature array to feature collection array
> array_push($geojson['features'], $feature);
> // Close database connection
> pg_close($dbcon);
> // Return routing result
> header('Content-type: application/json',true);
> echo json_encode($geojson);
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110824/72c61d01/attachment-0001.html
